I am working on an ampzilla II. The bias ic has a 4 transistor array. This one is shorted and took out the outputs. I know in the original 'zilla, there was no ic for setting the bias. Have you ever converted one? Also, what effect would lowering the bias a little have? If you have rebuilt one, what problems did you run into?
Thanks Roger
It's only dumb if you don't ask! |
#2 |
The original IC used in the Ampzilla was the CA3086, all later models used the MPQ6100.
An open bias IC would take out the outputs, not a shorted one. The shorted outputs took out the bias IC (unless you did not have it in contact with the heatsink). The stock bias level is fine. |
#3 | |
Roger
#4 |
It has a trim pot for the bias, R307.
Contact Us J&K Electronics Inc. 11-4 OLD DOCK ROAD YAPHANK, NY 11980 631-205-0005 FAX:631-205-9489 TOLL FREE 1-866-4JKELECT Contact us by E-Mail Don't like flames? Build a crowbar. |
#5 |
It has been years since I looked at an Ampzilla and their
magic "proprietary" chip, which as stated was an off-the-shelf transistor array. I'm sure you could replicate the functionality with a fairly normal Vbe multiplier, though you should reverse engineer the original circuit (given a schematic of the interior of the transistor array) to be sure.
bel |
#6 | ||
Roger
#7 |
That's just an ad from a search on the generic MPQ6100, give them a call.
ACK electronics in Atlanta used to have them too. |
| Gas Ampzilla | mharry | Solid State | 22 | 6th August 2010 07:08 AM |
| Help with Ampzilla II | native | Solid State | 11 | 6th March 2009 04:56 AM |
| Ampzilla 1 | flashmajik | Solid State | 8 | 7th February 2009 03:34 PM |
| My Son of Ampzilla | Dappel | Solid State | 12 | 18th December 2008 07:21 PM |
| Page generated in 0.10121 seconds (73.44% PHP - 26.56% MySQL) with 10 queries |
