Hi to all!
I've build various p3a amplifier. But i've noticed that with some output it doesen't work.. Why? I've build it with MJE4281 and MJF44H. But with MJW22191/2 desen't seem any way to make it work! Why? |
#2 |
Probably because none of those numbers are any good, not a one of them.
#3 |
Could u explaind a little bit more?
I'm not an electronic engeneer... What mean? |
#4 |
I have never heard about these transistors. Google neither.
I think they aren't in production. Or maybe they are home-made transistors, fabricated by you? |
#5 |
#6 |
Could you explain "doesn't work" ?
Maybe you accidently swapped pnp and npn, that's a trap with these devices, MJW21191 = pnp,MJW21192 = npn. I don't see any reason why these shouldn't work, except that they are not "state of the art"-devices. Mike |
#7 |
And what are the parameter that i should look to see if they're "state of the art" or not?
#8 |
The hfe-curve, 2nd breakdown (SOA), vbe-curve, maxdissipation,ft,
thermal resistance (junction to case) and so on. A very good transistor is the mjl3281a/1302a for example. The mjl21196/5 is also not bad. Or take a look to the sanken 2sc2922/2sa1216. Mike |
#9 | |
MJW21191 at +v and mjw21192 at -v right? |
#10 |
70-90% (EF output) probability otherwise
| A reason NOT to DIY.. | ScottG | Multi-Way | 114 | 8th June 2008 02:20 AM |
| Any reason not to consider this? | BHTX | Multi-Way | 9 | 2nd August 2007 08:21 AM |
| Any reason to add CDom? | TomasF | Solid State | 2 | 11th May 2007 02:55 PM |
| A(nother) reason NOT to DIY | AJinFLA | Multi-Way | 142 | 13th March 2007 03:04 AM |
| Page generated in 0.08905 seconds (87.06% PHP - 12.94% MySQL) with 10 queries |
