500 watt monoblock 500 watt monoblock - Page 5 - diyAudio
500 watt monoblock
500 watt monoblock
Old 12th April 2005, 02:08 AM   #41
RogerG is offline RogerG  United States
Originally posted by K-amps
Edl is A-ok on his advice. You can get 400 watts 8 ohms and 650 watts 4 ohms using a 800va Transformer with 62-0-62 vac volt rating with 86 vdc rails. If you want some Toroids for this, i can direct you to some cost effective vendors in the US.
A 500va toroid will drop rails and you will end up with 300-350 watts depending. A 1kva toroid with 95% regulation will get you up to 430 watts into 8 ohms. (All 86vdc). Using 93vdc will get you 470 watts 8 ohms and 96vdc with 95% regulation will get you 500 watts 8 ohms, however you will not find many circuits out there for 96vdc rails.
1kva@86vdc sounds good enough for me! But will 14vdc(?) be enough headroom? If not, what should be changed? Also, how many output pairs will it take to give me sub-4ohm stability?
Any vendors you would deal with would be greatfully welcomed. There is one good shop here and of course the few that I've on the net. But I'm all ways open for a deal.
Roger
It's only dumb if you don't ask!
Old 12th April 2005, 02:47 AM   #42
amplifierguru is offline amplifierguru
Account Disabled
It's possible to do a 500W/8ohm amplifier using two 32-0-32 transformers in series for approx 95V rails.
I would use MOSFETS as there's no SEC breakdown whereas BJT's are in sec breakdown territory for most of the range! So you're getting more of the pkg rating. A purely nch MOSFET output could easily deliver this from 8 pairs/channel to drive 8 ohm of any phase angle.
The design could then be a simple discrete amp driven by a chip from LF356 to OPA627 depending on quality budget!
PA or Audiophile ? Simple and inexpensive.
Next
Old 12th April 2005, 03:04 AM   #43
K-amps is offline K-amps  United States
K-amps's Avatar
Roger
Headroom is another name for a "not so well regulated" power supply. So I am not sure I get your question.
Old 12th April 2005, 03:58 AM   #44
jeff mai is offline jeff mai  Australia
jeff mai's Avatar
And as far as needing vs wanting 400-500 watts; I don't need a 500bhp 455 GTO either.
http://www.diyaudio.com/forums/showt...564#post617564
Sorry, I'll stop ******* in your cornflakes.
Old 12th April 2005, 04:23 AM   #45
AH! I do understand. Headroom is a common sales tool in high power amps. Carver(one of my favorites), touted it has a sign of high quality.
To Amplifierguru,
I liked your resent post about a/b class design. I've all ways been told layout has a large part in how an amp turns out. I'd love to hear more about your experience with this.
To Jeff,
"Sorry, I'll stop ****ing in your cornflakes."
I appolagize! I was a bit harsh, not to mention long winded. Please understand though, some of your post had just gotten under my skin.
Roger
Old 12th April 2005, 01:05 PM   #46
hienrich is offline hienrich  Philippines
hienrich's Avatar
to amplifierguru:
do you mind posting working schemes, I'm interested
specially the N-channels.
regards,
hienrich
500 watt monoblockHide this!Advertise here!
Yet another monoblock Sch3mat1c Solid State 4 22nd August 2009 12:00 AM
The best DIY monoblock? christianlie Solid State 10 17th December 2006 01:56 PM
3000 watt monoblock amp alphasonik Car Audio 5 31st August 2005 09:37 PM
New 220 Watt CMOS monoblock Leslie Horn Solid State 4 26th April 2005 06:57 AM
a 71A monoblock Joel Tubes / Valves 30 30th December 2002 09:19 PM
Copyright ©1999-2017 diyAudio
