My N_channel Mosfet Amplifier-opinion
Old 8th April 2005, 03:51 AM   #1
zox2003 is offline zox2003  United States
Default My N_channel Mosfet Amplifier-opinion
This is picture of MOSFET-amplifier I just finished.It is based on CITATION 12 schematic with some changes.It works very good.Output MOS are STW60N10.It delivers at least 120W on 4 ohms.
I took picture with my mobile phone(hmmm).
Old 8th April 2005, 04:24 AM   #2
amplifierguru is offline amplifierguru
Account Disabled
Cute - got a schematic?
Old 8th April 2005, 04:29 AM   #3
Arrow yep
Yes i do on paper ...
I have to draw all changes I made....
I will post it soon...
Old 8th April 2005, 12:09 PM   #4
darkfenriz is offline darkfenriz  Poland
darkfenriz's Avatar
I see you've nicely isolated mosfets' dies from each other. How do you isolate the screws?
Old 8th April 2005, 03:42 PM   #5
Default SCrews???
They do not have to be isolated.MOSFETS are in TO247 case.No need for screw insolators.
Old 8th April 2005, 06:33 PM   #6
ilimzn is offline ilimzn  Croatia
Did you include the last changes we discussed?
Old 8th April 2005, 06:52 PM   #7
Default Yep...
Yes I did and I am attaching a waveform -square for 10khz.Check it out.
This is on +/- 32V rail ( lab.power supply)-testing purposes.Amplifier will run on +/- 42V.
Does it look good?
Old 8th April 2005, 08:01 PM   #8
Note how the rising edge of the square wave has an indentation when crossing zero - this is indicative of low current capability of the VAS, but probably more of low bias.
Keep in mind that when you change the rail voltage, the VAS current changes in proportion, and also the bias voltage and hence standing current changes - in your case both get lower. You need to re-adjust bias when you change rail voltages on this design.
Adjust the bias current so this dissapears, just be careful to monitor what it is as on the MF12 design turning the bias pot all the way to the end will result in infinite standing current!
The reason why you get rising edge distortion, but not falling edge is because the VAS current pulling down has a FAR larger limit. In essence, the lower MOSFET can be driven on with a very large current (limited by R19). The upper transistor can be driven up only by the current of the bootstrap VAS (Vrail / (R3_R4)).
If you get oscillation when zero crossing, you may also experiment with the gate damper resistors on the MOSFETs, especially the upper one. This will not make the notch dissapear but may make it less jagged. Then, adjust as best possible with bias current.
Old 8th April 2005, 11:10 PM   #9
darkfenriz's Avatar
sorry Ithought they were to220
Old 9th April 2005, 11:46 PM   #10
I just noticed in your diagram you were running the amp into clipping, in which case most of what I said in my last post may not apply. It is difficult to see anything of the natural response of the amp when driven by a square wave into clipping... the notch on the rising ende may be due to that alone.
My N_channel Mosfet Amplifier-opinionHide this!Advertise here!
mosfet opinion? tadiam Solid State 13 30th March 2007 05:33 PM
35W MOSFET Power Amp - Your Opinion binary Solid State 20 17th November 2006 12:25 PM
Opinion about this hi-fi amplifier viktor1986 Solid State 31 15th November 2006 03:12 PM
opinion on MOSFET amp? AudioGeek Solid State 1 1st September 2004 05:22 PM
Elektor- MOSFET 'valvesound' amp opinion mikee12345 Solid State 0 7th August 2004 06:53 AM
Copyright ©1999-2017 diyAudio
