What every Class AB builder needs to be constantly aware of
Old 18th May 2005, 04:14 PM   #211
Re graphs in posts 202&203.
the 10*2.2mF cf 22mf makes sense, the hf performance of 10*2.2mF is superior due to the effect of the smaller caps(less inductance).
The 10*2.2mF cf 1*2.2mF also makes sense. The high frequency performance is dropping off slightly due to the added inductance of the interconnections.
The movement of the minima relative to frequency tell a large part of the story.
It appears from these that many small caps are always better than a small number of large caps provided the interconnections are kept very short.
Has anyone come up with an explanation for the weird behaviour of the earlier paralleled comparison graphs that show gains much greater than 10* and at higher frequencies?
regards Andrew T.
Old 18th May 2005, 06:04 PM   #212
B Cullingford is offline B Cullingford  United States
Jacco:
At the risk of going to far off topic, what I was questioning was whether you had inadvertently mixed the weak and strong in phrase: "A combination of a weak spring and high mass has a much higher resonance amplitude compared to a combo of a stiff spring and low mass, despite occuring at the same frequency."
However it seems to me that the weaker a spring is the lower the f of oscillation of a spring pendulum, and increasing the mass will also reduce the f, so weak spring + low mass will have same f as strong spring and high mass. High mass and strong springs will have more stored energy for a given amplitude, the amplitude will depend on the energy put into the system (we can also see that the higher the f of oscillation the higher energy since the mass is moving faster)
I too like simple comparisons, though I love math as well and it often gives futher insights into a system.
As to the topic at hand - I have often thought that multiple smaller caps could have advantages but neither properly done the math or tried. I suspect that implementation has alot to do with the results stray inductance and the like.
Old 18th May 2005, 08:16 PM   #213
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
True, reverse.
W= SQRT (K/M) K = spring stiffness. W in radials per second.
this is transferred to C= 1/K
=> W = 1/ SQRT(C*M).
C*M = constant=> same resonance frequency.
Means high spring stiffness and high mass, or weak spring and low mass.
A weak spring and low mass has higher ampitude, but the same resonance frequency as a combination of rigid spring and high mass.
Just as confusing as C/W and W/C.
I am getting old, and shouldnt be posting when i am too busy with work, sorry.
I meant to say that as the spring-mass system is often mathematically compared to an RLC system, putting a number of capacitors in parallel may be mathematically comparable with a system of coupled springs and masses.
I mentioned this because i remember from the time that i practiced matrices for multiple spring-mass systems in finite elements programming a long time ago the graphs looked identical.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 18th May 2005, 09:25 PM   #214
Jacco, - I know that feeling. And I don't want to get into that math right now - studying water rocket math right now water rocket thrust equations
with R being equilavent to damping.
Lots of coupled pendulums can lead to chaotic looking behaviour - maybe an indication that just paralleling lots of caps without due consideration to layout, trace inductance etc is maybe not the best solution. Or to put it another way YMMV, according to your path.
Bill
Old 18th May 2005, 10:13 PM   #215
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Having considerable experience with bedsprings, I believe
you're right.
Old 18th May 2005, 10:48 PM   #216
you're right.
is it already time for the size 12 again, Mr Pass ?
Old 18th May 2005, 11:14 PM   #217
Originally posted by B Cullingford
studying water rocket math right now [/URL]
Thanks for posting the link to the water rocket equations, Bill.
I had one of those when i was 10 years old, my uncle brought it as a present from the states.
Unfortunately it broke on the pavement, by the time they sold them overhere i was too old to play with water rockets.
When i moved to the US i only had eyes for other creatures.
I do like math, i will enjoy reading the stuff.
Old 19th May 2005, 05:51 AM   #218
amplifierguru is offline amplifierguru
Account Disabled
That bedspring would be an analog(ue)?
Old 20th May 2005, 03:23 PM   #219
Workhorse is offline Workhorse
Workhorse's Avatar
Originally posted by amplifierguru
Thanks guys.
Now with each output half having to deliver half the waveform, just look at the spray of harmonics that are generated in and around the outputs and power supply lines
Hi Mr.Greg,
Your posting displayed the spray of harmonics in supply lines as well.
My WISE question is this what will happen when a birdged amp sprays the harmonics, Aren't they cancelled[I may be Wrong] due to out of phase waveforms in case of harmonic spray.
Kindly , share your views with regarding us.
Sincere regards,
Kanwar
What every Class AB builder needs to be constantly aware ofHide this!Advertise here!
Copyright ©1999-2017 diyAudio
