Old 7th April 2005, 09:57 AM   #1
Send a message via ICQ to martinlo
Question Is this amp suitable to put like this way? (With photo)
As title.
Luxman R-1040
Is this OK?
Old 7th April 2005, 11:02 AM   #2
tinkerbell's Avatar
Send a message via AIM to tinkerbell Send a message via MSN to tinkerbell Send a message via Yahoo to tinkerbell
you should try to maintain the heatsink fins perpendicular to the ground as heat rises
unless it is fan forced.
can you describe the heatsinks? are there holes in the top of the amp to let heat out?
Old 7th April 2005, 12:13 PM   #3
Is this OK?
Old 7th April 2005, 01:28 PM   #4
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
No, if it is an amp that tends to run hot or just you like to crank up the volume, it is not its optimal position. As stated by other fellows, you must mantain the heatsink perpendicular to the floor to mantain air flow. Unless of course if fan cooled.
Can you post a picture of the heatsinks? Maybe they're mounted in a particular way...
Old 7th April 2005, 02:23 PM   #5
ilimzn is offline ilimzn  Croatia
Simply put: NO.
The R1040 already has a relatively small area heatsink that is designed as vertical 'chimneys'. If you put it to the side, it wil not have adequate cooling.
Can't attach Photo's c2cthomas Forum Problems 3 13th May 2007 12:29 PM
Suitable regulated/filtered 4volt battery-valve power supply suitable for 6+ valves? Layberinthius Tubes / Valves 0 11th March 2004 08:49 PM
My DAC Photo MCLL Digital Source 4 27th April 2003 09:47 AM
Page generated in 0.07916 seconds (69.65% PHP - 30.35% MySQL) with 10 queries
