I've done a fairly substantial amount of reading in Self's Audio Power Amplifier Design Handbook , and I believe I have a quite good grasp on how each section works, etc. But looking through the book and every resource I have been able to find online, I can't find anything that tells me how to even START selecting specific component values and such. I would really like to design and build my own "blameless amplifier," but this seems like an insurmountable problem. Please help.
Thanks in advance, Scott |
#2 |
Account Disabled
scott,
I can probably help you as I was designing commercial PA amplifiers very similar to Douglas Self's designs - back in 1974 using MJ15003/4. The one thing he glosses over and is a prime concern of mine is PSRR or Power Supply Rejection Ratio. Miller compensated amps are particularly prone and even his own example benefitted greatly, from memory, with THD dropping from 0.04% to 0.008% simply be adding a regulated power supply. If that isn't an indication of supply sensitivity I don't know what is. The same occurs in many integrated OP amps where chip space is at a premium and capacitors consume real estate. The usually opt for the smallest on chip comp capacitor which is a miller cap and the PSRR to that supply side goes down the toilet. Rarely do they bring out a comp to ground pin. The basic Self amp topology has great potential particularly with FET inputs, bipolar or CFP MOSFET outputs and comp from the Vas output to NFB return point. Hope that helps. |
#3 |
There was some great information in there, but I still don't know where to start deciding on values for each resister and capacitor and transistor, etc.
#4 |
Account Disabled
You need to identify the goals your amplifier is to achieve. Power, THD , crosstalk, budget.
Identify Type of output BJT or MOSFET? work out supply rails Regulated or unregulated? how many channels 2 to 6+ . If you want you could run them all off one power supply in one big box? What quality source are you to use? |
#5 |
hmm... looking at more schematics, most of the resistors and caps and such look predetermined. If this just leaves the transistors and rails and such, do I figure out how much power I want, and what rail voltages, and then pick transistors based on these values?
#6 |
Self is good reading. I second the removal of the Miller comp cap and choose a Leach or Cherry feedback topology or as amplifierguru suggests for HF feedback. Read the tech notes in the ESP site along with the schematics etc. Start with a lower voltage PSU (+-40v?) and save blowing up your transistors until after you have understood temperatures and why they happen, protection and how to implement and peak currents/voltages and their effects on components.
regards Andrew T. |
| Newbie question re: "Proper" cabinet design | Ken C | Multi-Way | 5 | 8th June 2004 08:14 PM |
| Newbie needs help. Basic PSU design and choke question. | RockysDad | Tubes / Valves | 8 | 18th February 2004 06:37 AM |
| Gainclone & speaker design question. Newbie looking for help! | matjans | Multi-Way | 13 | 19th October 2003 06:31 PM |
| I am so old I forgot my question, please do not respond | ststone | Everything Else | 0 | 11th December 2002 05:04 AM |
| newbie post, but hopefully not a newbie question | wiredcur | Solid State | 3 | 24th August 2002 11:49 PM |
| Page generated in 2.55821 seconds (-67.54% PHP - 167.54% MySQL) with 10 queries |
