Old 5th April 2005, 08:33 PM   #1
Default impedance matching options sought
I have a 250K stepped attenuator that I wish to use as a passive linestage before an active line-level crossover/equalizer. The input of the xo/eq consists of a 6th order RC LP filter for RFI attenuation on the non-inverting input of an opamp, while the opamp then implements a shelving high-pass filter. The RFI filter has a nominal 10K input impedance.
I can see several options:
(1) recalculate the input circuit values to have an impedance of 100K
(2) add a buffer with 100K input impedance before the input circuit.
(3) transformer coupling
Are there any others?
I'm not interested in transformer coupling, might as well replace the passive with a TVC if I was to go there.
Other than parts count and/or cost, the only tradeoff I can see between (1) and (2) is more resistance/noise in the signal path, vs. an extra opamp. Any others?
- Eric
Impedance Matching maxzimum Solid State 2 9th April 2009 02:03 PM
Impedance matching Triod lover Tubes / Valves 2 12th January 2007 09:59 AM
Help with Impedance Matching mudihan Pass Labs 6 14th July 2006 10:35 AM
Need help understanding transformer impedance ratios and impedance matching percy Tubes / Valves 5 28th February 2005 08:35 PM
Impedance Matching bryce66 Solid State 6 9th November 2001 09:02 AM
Page generated in 0.06737 seconds (64.33% PHP - 35.67% MySQL) with 10 queries
