Old 4th April 2005, 08:16 PM   #1
zox2003 is offline zox2003  United States
Default Another Amplifier Check Please
CAn somebody check this amp and tell me if it looks good and how much power I can expect from this?
Old 4th April 2005, 08:53 PM   #2
darkfenriz's Avatar
looks like Pass' Citation
visit http://www.passdiy.com
Old 4th April 2005, 09:00 PM   #3
I didn't check the amp but if it works well, the power at 4 ohm will be about 175 Watt.
Marc.
Old 4th April 2005, 09:07 PM   #4
ilimzn is offline ilimzn  Croatia
Looks like an (over)simplified Citation 12 MOSFET mod, which can be found on www.passdiy.com under archived projects, under the name MF12.
A couple of important omissions in the above schematic:
Gate of the top MOSFET should be connected via a diode (reasonably fast, 100V minimum) to + rail. Otherwise the amp will clip asymetrically and may actually overdrive the MOSFET gate above the maximum 20V resulting in it's destruction.
MOSFET gates may need series damper resistors (47-100 ohms).
There is no short circuit protection which may be good and bad, usually good while the amp is working and bad when it stops
In particular, if fuses are added, in a short circuit condition it is likely the amp will not fail due to MOSFET failure, but the failure of the MPSA56 driver for the bottom MOSFET, once that dies, the MOSFETs may follow...
The MPSA56 mentioned above will need a heatsink.
A non-inductive foil cap cca 22-100nF across the Vbe multiplier will help HF distortion.
There are a number of improvements that can be made to this simple amp but it will work fine as it is.
Maximum voltage (before clipping) from this amp will be about 5V less than the power rails. Assuming no rail sag (BIG assumption!!!), that would be 170W into 4 ohms. A more realistic figure would be about 100-120W with a really good power supply.
Old 4th April 2005, 09:16 PM   #5
Default Thanks..
Opet si tu....
What quality can i expect from this amp.Would it be better if I replace MJE340 with IRF540 with modified Vgs circuit?
Old 4th April 2005, 09:20 PM   #6
Default MPSA56 replacement???
What would be good replacement for MPSA56 in driver stage?
Also should I replace MPSA06 with something else?
ilimzn,
Po kvaliteti dali je bolja sema koju si ti postirao u mom proslom postu ili ova?Da li tvoja verzija moze da radi na +/- 42V bez ikakvih izmjena ( tranzistori,otpornici...)?
Old 4th April 2005, 09:26 PM   #7
Default ilimzn question???
Da li na tvojoj semi mogu da zamijenim 2n5551 sa mpsa06 i 2n5401 sa mpsa56?
hvala
Just question about transistors replacement?
Old 4th April 2005, 09:27 PM   #8
The rule is to compensate with the same kind of element as the one being compensated. That way you get the best thermal tracking.
In this case using a Vgs multiplier would not be adequate because the bottom MOSFET and it's MPSA56 driver form Compound Feedback pair (a.k.a. Sziklai pair). Thermally, CFPs behave almost entirely like the first element in the pair, in this case it's a BJT, the MPSA56.
So, you have a BJT and a MOSFET combination. A Vgs multiplier would have too low a temperature coefficient for the BJT part so you have to use a Vbe multiplier to account for this. Still, the total combo will have a lower tempco than the Vbe multiplier, which is why there is a resistor added in the Vbe multiplier's emitter, to make it a better match.
Old 4th April 2005, 09:33 PM   #9
2N5551/2N5401 could be substituted with MPSA06/56 but in this amplifier as well as the one I posted the MPSA parts are at the limit (Vcemax=80V, the rule is Vcemax>(|-rail|+|+rail|). Not for all transistors in the circuit, but in the case of the above amp, definitely the MPSA06 VAS transistor is at it's limit (it will need a heatsink but that should have been obvious).
Fortunately, you are not violating Vcemax by much (4V) so you might get away with it - if it was me, I'd be looking at other transistors.
Old 4th April 2005, 09:41 PM   #10
Default Which amplifier ,than?
So you still did not answer on my question:
What quality can I expect from this amp?
and
Which one would be better: your amp you posted 3 in my last post or this one?
Also is it better to use two n mosfets( like in this amp) or n and p mosfets (like in your)?
regards,
zox
Intrest Check: 120w @ 8ohm Tube Buffered LM3875 Amplifier rhysh Chip Amps 189 30th May 2010 06:54 AM
PCB Check Khron Chip Amps 48 28th May 2006 09:55 PM
Sanity check - designing my speaker to be 8ohm amplifier friendly. owdi Multi-Way 4 1st November 2005 10:08 PM
Mystery Amplifier - check it out lgreen Solid State 16 13th January 2005 02:51 AM
Page generated in 0.14556 seconds (75.43% PHP - 24.57% MySQL) with 11 queries
