Old 5th April 2005, 11:15 PM   #21
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally posted by joensd
what you do is bias the output stage so probably 2?
imo, there is very little use in running all other stages biased if the last is not, Jens.
I do not like the sound of any (mos)fet in AB mode.
I noticed a more substantial difference with opamps that have fet stages, that was my point.
Looks like Sponge Bob has killed another thread.
Old 6th April 2005, 02:49 AM   #22
Account Disabled
Kanwar,
Sure you're not exceeding the 2N5551's rating on 18V supplies?
BTW what is the 1K and 20K THD of your Workhorse amp?
Old 6th April 2005, 06:54 AM   #23
B.VDBOS is offline B.VDBOS  New Zealand
B.VDBOS's Avatar
What about this
Old 6th April 2005, 07:32 AM   #24
Account Disabled
Yes what is it? It has serious PSRR issues, capacitors in the signal path and no gain.
No gain lots of pain.
Old 7th April 2005, 04:54 AM   #25
B.VDBOS's Avatar
The idea was to have one opamp with +ve offset and the other to have equal but opposite - ve offset (Im not sure if this is the correct way to do this) so current flows between the two opamps forcing them in to class A
Gain is easy, just add resistors
Capacitors could dubble as input caps which are a nessercery evil anyway, thats if you think capacitors are bad in the first place
Anyway just some brian food
Old 7th April 2005, 04:57 AM   #26
possibly missing some form of current sharing resistance? as it stands thats probably going to make real opamps very unhappy!
if only it could be used for good, not evil...
Old 7th April 2005, 05:15 AM   #27
B.VDBOS's Avatar
The idea is to have current flowing between the opamps on purpose so current sharing resistors may not be nessercery?
My thinking is comming from over biossed AB amps where one transistor is sorcing current and the other is sinking current at the same time
In this case opamps take the place of the transistors and having the bois at the input each opamp would force class A all the way though (again just a thought)
Old 7th April 2005, 05:17 AM   #28
Account Disabled
BVDBOS,
I see what you're trying to do. The problem is most OPamps have poorer PSRR on the miller comp side - or one side anyway and better NPN side stability so the tendency is to favour the upper half and load it down to the negative rail. Even better to the unreg negative supply!
Having said that the best way is with a distortion meter and residual showing for each different one. That's the way to optimise.
I have to agree with jacco that FET input chips is the more noticeable improvement . Both is excellent. I modified some
Meridian DACs this way with good results. Those damn 4 layer boards.
Old 7th April 2005, 05:30 AM   #29
B.VDBOS's Avatar
BVDBOS,
Maby the scamatic I posted would be better for those who want to play with class A power opamps like LMxxxx ect.
It (class A) would add to the majic
Old 7th April 2005, 07:29 AM   #30
Account Disabled
Thats a cute little drawing package . What is it?
low distortion measurements and forcing opamps to class a mlloyd1 Solid State 3 3rd July 2009 01:05 AM
FS: Power Chip OpAmps and other OpAmps & D to A Converter dtm1962 Swap Meet 4 12th January 2006 11:07 PM
biasing opamps in class a matjans Chip Amps 33 19th December 2003 05:05 PM
Class A biasing of opamps DrewP Solid State 25 24th October 2002 12:18 AM
Why do so few designs use opamps working in class A? fmak Solid State 19 23rd May 2002 04:25 AM
Page generated in 0.10964 seconds (80.30% PHP - 19.70% MySQL) with 11 queries
