Old 5th April 2005, 03:19 AM   #11
Account Disabled
I too have done much testing and application of Class A output stage forcing of chips particularly the FET input chips LF357,( decompensated), TL081, and OPA627 - while viewing distortion residual waveform.
The results varied widely with chips from different mfgrs giving different results. So there is no rule of thumb each type and make will have a different optimum and benefit. You need a quality distortion analyser to do anything definitive.
Old 5th April 2005, 04:11 AM   #12
diyAudio Moderator Emeritus
How much current needed in average opamp type (NE5532, TL072, etc) without putting heatsink on top of the chip (and works safely for long time)? 1mA? 5mA? 10mA?
I noticed OPA134 series has already draw about 5mA. Does this chip has already works in classA without outside forced bias?
Old 5th April 2005, 04:21 AM   #13
Account Disabled
lumanauw
You cannot easily determine theoutput operating state of many opamps. You can insert resistors in the supply leads and raise the signal into a load to determine a point of transition for the output stage but it's very rough.
regarding power dissipation it's the supply voltage x the standing current consumption. The data sheet will tell you the case dissipation and derate for temp rise. Remember your constant current only forces half output stage dissipation. So determine your max demanded current to the load then add a couple of mA and set the current source to this. Then to finesse you need a THD analyser.
Hope that helps.
Old 5th April 2005, 04:24 AM   #14
B.VDBOS is offline B.VDBOS  New Zealand
B.VDBOS's Avatar
I've thought about that to
If Im not mistaken the opamp will be in class A if the output current is less than the quiesent current, which for most line level applications it is, even in to a 1K load
Old 5th April 2005, 04:32 AM   #15
sam9 is offline sam9  United States
sam9's Avatar
I seem to recall from an appnote somewhere that using a resistor btween output anv -V can afefct the input impedance of the next stage as seen by the opamp you are lifting into class-a. This doersn't necessarily mean you have a problem, but you need to be aware of it in the context of the particular opamp you are using and what you are doing with it.
Old 5th April 2005, 04:44 AM   #16
nuvistor's Avatar
LM359 output stage is NPN darlington with NPN current sink, pure class A. The sink current can be programmed with an external resistor or current source. This is an early 80's "Norton" op amp like LM3900 but with video bandwidth, needs a discrete first stage to be useful with high impedance sources. Max voltage rail-to-rail is 22V. It's still available from National Semi.
NE5534 output stage is totem pole, Q13 is upper NPN, Q17 is lower NPN, with diode D5 in series with lower NPN collector, driven by NPN phase splitter Q18, assuming I've read the "simplified schematic" correctly. A PNP emitter follower Q22 completes a feedback loop from Q17 collector to Q18 base. Q17 collector is connected to pin 5 which is normally used for compensation but can be used with a current source for a single-ended class A output that can sink at least 15mA and has no current limiting if output pin 6 is open. The schematic I refer to is available here .
For NE5534, a single op amp, in DIP package, maximum dissipation is about 500mW at 25C with thermal resistance 160C/W and 105C chip temperature. With 4mA typical supply current and +/- 15V rails, dissipation is 120mW. With no output load, up to 380mW can be taken by a class A current sink, or 25mA at 15V. 10mA sink at 15V causes 150mW dissipation, leaving 230mW or 15mA output current available. 5534 output pin can sink/source 50mA so its current limit will not activate.
Op amp output stages are class A up to a certain current depending on the design, if an op amp has supply current of 5mA, this does not mean that its output is class A up to 5mA. As amplifierguru says, if you really wanted to you could measure the class A-B transition current by applying a load to ground and measuring the current in a supply pin while applying an input, if the output is positive the negative supply pin current will decrease only a certain amount, this decrease should match the built-in class A bias current.
Old 5th April 2005, 02:56 PM   #17
Workhorse's Avatar
Send a message via Yahoo to Workhorse
Smile Hi buddy
Originally posted by richie00boy
kanwar,
I use the OPA134 and OPA2134 myself as it's a really nice chip. I believe it has a quasi-complementary output as the max swing available to each rail is not symmetrical (see output voltage swing vs output current graph). Because it can swing closer to the lower rail I believe that one is the quasi side. No PSRR data is given for the individual rails so I have to base my choice on the output stage symmetry alone. Therefore I hang a current source made from 2N3819 JFET and resistor off +ve rail and down to the output as I believe the cfp/quasi side works better in class-a and also there is more swing available.
I hope this brings you success and nice sound
Hi Ritchie,
I have applied the constant current source with a transistor 2N5551 at about 10mA, with +-18V supplies. The result was astonishing and the sonic detail was something to heard off, really this chip in class-A works extremely well.
I also think that this chip is quasi comp.
The max. output swing i get is 10Vrms with 1kiloOhm load, and that too at frequency at 30kHz.
There is also another Chip IN134, IN2134 from texas instruments which has internally laser trimmed resistors which result in differential gain of one. there is no need to put extra resistors which saves space and of course cost of resistor......HaHa.
Now the sound of our workhorse amp would be much much better!, ThanX alot.
This discussion is getting high slew rate.........
regards,
Kanwar
Old 5th April 2005, 10:24 PM   #18
The one and only
Nelson Pass's Avatar
Originally posted by Leolabs
One famous US amp maker(can't remember which one)did use this opamp for their power amp with forced-bias arrangement.
Barry Thornton used external Class A bias on his 709 op amp
front end in the Quintessence amp around '72. This is the
first place I saw it, although it's an obvious enough idea that
it may have been done elsewhere first.
Old 5th April 2005, 10:50 PM   #19
joensd is offline joensd  Germany
With all the "opamp into class-a" fuzz you gotta remember what you wanna achieve with it. Audible/subjective improvements?
Hard to measure the distortion of a OPA627 anyway so...
think of the number of fets in an opamp.
what you do is bias the output stage so probably 2?
jens
Old 5th April 2005, 11:09 PM   #20
Did it Himself
richie00boy's Avatar
That's true but probably most of the other devices in the chip are working in class-a. It doesn't hurt to try and wring the last bit out of the chip -- that's why we DIY
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
low distortion measurements and forcing opamps to class a mlloyd1 Solid State 3 3rd July 2009 01:05 AM
FS: Power Chip OpAmps and other OpAmps & D to A Converter dtm1962 Swap Meet 4 12th January 2006 11:07 PM
biasing opamps in class a matjans Chip Amps 33 19th December 2003 05:05 PM
Class A biasing of opamps DrewP Solid State 25 24th October 2002 12:18 AM
Why do so few designs use opamps working in class A? fmak Solid State 19 23rd May 2002 04:25 AM
Page generated in 0.12954 seconds (81.60% PHP - 18.40% MySQL) with 11 queries
