Regulated Power supplies
Old 27th August 2002, 03:51 PM   #31
Petter is offline Petter
Default Instead of throwing away caps
One of the reasons why REALLY big transformers are needed in high-end equipment is the short conduction angle.
Try using a series resistor to increase the conduction angle. This can be done at transformer OR between banks. I would try a small bank followed by an RC large bank.
Petter
Old 27th August 2002, 06:58 PM   #32
chris ma is offline chris ma  Canada
chris ma's Avatar
Default series resistor?
Peter,
Can you specify some RC values and component layout please. Are you suggesting there is no need to reduce the capacitance of my PSU?
Old 27th August 2002, 07:59 PM   #33
traderbam is offline traderbam  Europe
traderbam's Avatar
Using a transformer/rectifier/cap method is one of the crudest ways to get dc from ac that exists. It is like trying to levitate your body by being continually kicked up your backside. Some decades ago choke regulators were fashionable. I suppose the economics of silicon caused the demise of the choke. Choke regulators smooth the rectified current pulses whilst conserving energy (a resistor shunt wastes power). The disadvantage is cost and space and a more complicated design equation.
BAM
Old 27th August 2002, 10:13 PM   #34
ALW is offline ALW  United Kingdom
Default Hold on, part II
I've found that adding series resistors is detrimental too, although I've not done significant experiments.
There was an obvious reduction in noise, but the sound was more than a little dull and unexciting to listen to.
Yaaawn...
I have a little theory (that I'm keeping to myself at present ) that relates capacitor size to transformer parameters.
It seems to work for all the designs in which I've tried it, but finding optimal capacitor values in PSU's gets expensive.
I've one to build soon and will be trying caps either side of my calculated value - if it works I may reveal more. The problem at the moment is I don't understand the mechanism by which the degradation arises.
I can't obviously measure the effect, yet I can hear it. It may be related to the waveform on the secondary - take a look at it with large caps in place - not really sinusoidal at all. This flat-topping gives some harmonic content we don't want, but adding series R before the caps doesn't improve the sound, just changes it.
A.
Old 27th August 2002, 10:15 PM   #35
Default Bam
About the best description I've read yet
I've been meaning to try choke reg's - you've just spurred me onto trying it, along with another chat I had recently with a designer about the lost art of inductors!
Will report back when I try it.
A
Old 27th August 2002, 10:30 PM   #36
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Default Choke input
From the Radiotron Handbook:
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th August 2002, 11:27 AM   #37
chris ma's Avatar
Red face Report Sir
Andy is right (ALW), Thanks.
I removed two 15,000uf from the rails, each rail now has one BHC Aerovox ALT22A 15,000uf 63V and bypassed by three 100nF polypropylene caps left on the rails. Kept everything else the same as before.
The sound of the amp changed ;
Treble now has more dynamic and forward, cymbal sound better than before, I do not know how to describe it but it sound clearer overall from mid to high frequency. The amp seems to be a bit more sensitive, but then it seems a little thin, more airy around instruments. Actually there is one track on a old CD clipped badly with high frequency during a particular short loud passage of the song. May be just the bad recording I do not know.
But the heat of the bridge rectifiers and the transformers got just as hot as before though. No luck there.
Andy, once you have found the optimum cap & tranny formulae please share with us...
Chris
Old 28th August 2002, 02:40 PM   #38
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Regulated Power supplies Send a message via AIM to Peter Daniel
What about the bass?
I don't think that amount of capacitance has anything to do with the bridge temp. Once the caps are charged the current draw from the amp influences the bridge's temperature. Just put it on a heat sink and forget that it's hot. I placed my bridges on the same heatsink as output devices and they were around 55 deg.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 28th August 2002, 03:20 PM   #39
chris ma's Avatar
Default Bass? Not much changed that I can hear yet..
At first I thought the bass was reduced (first impression) right after the modification ; due to the more dynamic mid high caught my attention, then I turn my attention to the bass and ignore the mid high of a couple of recordings that I know best, is all there, just as same as before the mod.
I'll give it a couple of days listening then I will put one cap back per rail (2 X 15000uf per rail) to check the result. For now there are certain tracks it sounds just a little bit too bright in the vocal department for my liking. Mind you the cymbal and hi-hat sound great now. The track Ready for love by Bad Company sound really good with the drums now, used to sound a bit strangled, bass stays the same however, did not have time to listen to my reference CD yet the Sheffield test cd titled "My Disc". Will do that tonight.
Old 30th August 2002, 05:57 PM   #40
Hoffmeyer is offline Hoffmeyer  Denmark
Default Real-world picture:
planet 10.
I get very nostalgic when I see such a textbook picture.
This is what I've measured during the test of my LDO-regulator today:
Perhaps the phenomena in question has something to do with the relationship of the inductance of the secondary - the resistance from the secondary to the capacitors - the capacitance - and the waveform ??
Hoffmeyer ;0)
Regulated Power suppliesHide this!Advertise here!
Need Help with + _ 90-100 volt regulated power supplies wrich22 Power Supplies 4 21st March 2008 10:46 PM
Regulated power supplies and capacitance Greg Erskine Chip Amps 33 3rd October 2004 09:56 PM
Regulated power supplies in a Gainclone Dr.H Chip Amps 30 11th September 2003 06:55 PM
FS: (2) 28 VDC 11 AMP regulated power supplies. FEThead Swap Meet 1 2nd May 2002 04:18 PM
Regulated power supplies Jason Hubbard Solid State 20 10th September 2001 08:33 PM
