Old 1st April 2005, 08:02 PM   #1
Default Transformer ok for power amp??
I picked up a 35-0-35 280VA transfomer last weekend with thought of using this to build a power amp.
Is current capacity not adequate for a 2 channel amp?
Please excuse question from newbie if not within scope of this fourm.
Old 1st April 2005, 08:06 PM   #2
Did it Himself
richie00boy's Avatar
It's just about OK for an 8 ohm load. You should be able to get about 70-90 watts RMS into 8 ohms per channel.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 2nd April 2005, 10:06 AM   #3
Thanks for info.
I can likely get another one of these xformers cheap (used - @ about $16USD) and was thinking of hooking the two up in parallel for extra current capacity.
I have a pile of 2N3773s that I salvaged a few years ago that I wish to use as well.
Cheers
Old 2nd April 2005, 11:52 AM   #4
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
Well... you 2N3773 looks good, it is a new 200°C max transistor, 160V 150W. I guess you can do dual mono with the 2 transformers (or just build 2 monoblocks ) and get an hundred of watts per channel... maybe with that high voltage and not so high power rating you need to parallel the output transistors...
Just my 0.02
(eheh... I know how a diy-maniac feels when he has stuff for cheap... )
Old 2nd April 2005, 06:29 PM   #5
Did it Himself
Yes, I would go for the dual mono rather than parallel. Although as I said one will be OK for use with 2 channels as long as you aren't into cranking it up all the time and your speakers are an easy load.
Old 2nd April 2005, 06:55 PM   #6
the 2n3773 is a robust 150w transistor, well suited to quasi topology.
Temp rating is Tjmax=150degC.
It has very good current handling at medium voltages, the knee in the SOA curve is at 100v making it better than many 250v & 350v transistors. Power rails of +-50v to +-70v are usable even though it is a 140v device.
Keep them cool if you do push the voltage envelope.
Single pairs work into 8r and medium 8z.
Twin pairs for 4r and medium 4z and difficult 6z.
I second the dual mono route for the transformers.
As a monoblock you should achieve 120w into 8r on 55v rails.
regards Andrew T.
Old 2nd April 2005, 07:56 PM   #7
Thanks for all the great feedback.
I picked up 2nd transformer this morning and am now leaning toward dual mono block design for power amp.
I don't really need a another power amp.
I have a Bryston 4B for living room audio system, a pair of Crown DC300A Series II in my listening room - running bridged mono, and a pair of Crown D150As stored in thier boxes for last 5 years.
However, I have always wanted to build my own power amp. I'm sure it will sound the better than the others :-)
Old 3rd April 2005, 01:02 PM   #8
Giaime's Avatar
Yeah, it will sound better, because it's your own
I would do a dual mono, quasi complementary, +-55VDC rails, paralleling 2 transistors per side (you'll need 8 of them for the whole thing) for difficult loads.
Good luck!
Power transformer Alain Dupont Tubes / Valves 4 4th April 2005 09:12 PM
Power Transformer tenderland Tubes / Valves 1 19th January 2005 06:42 PM
power transformer help !!! jim Tubes / Valves 2 9th January 2004 09:59 PM
toroid Transformer as power Transformer for tube tone Tubes / Valves 7 11th February 2003 08:57 AM
Good price on huge power transformer for power amp. G Solid State 3 15th September 2002 01:23 PM
Page generated in 0.10313 seconds (75.39% PHP - 24.61% MySQL) with 10 queries
