Old 1st April 2005, 05:00 PM   #1
BOCHIN is offline BOCHIN  Argentina
Send a message via MSN to BOCHIN
Exclamation Bass Amp Failure
A friend of mine gave me his Bass Amplifier so that I could repair it. He said that it stopped working when he accidentally placed the wrong kind of speaker to the system (he has 8 ohms outputs and connected 4 ohms speakers, pretty lame!).
I checked all the output transistors and one of them was dead, changed it and had to repair the board because it had lots of broken paths. After doing this y plugged it in and sparks flashed from the board, I thought it was a short circuit somewhere, checked it and nothing was apparently wrong, after this I plugged it in again and smoke come from one of the output resistors.
The funny thing is that the resistor that burned was from the PNP transistors side, and the trasistor that was dead was a NPN...
Please help!
Another thing, smoke came out of the resistor... is it dead?
The amplifier is a Trace Elliot of 150 W, I have the schematic, any help will be apreciated.
Old 1st April 2005, 07:25 PM   #2
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
So... let's start with the easy things. Yes, smoking resistors need to be replaced since they're unable to dissipate their nominal value of power.
The not-so-easy thing: well in a transistor amp you can't just replace the output transistor you found dead. Most of the time a dead tranny (and remember to say if open or shorted - it is important) takes away with him driver trannies, resistors, diodes, pots, etc... so check everything! I really mean EVERYTHING! Capacitors (even power supply ones), the power rectifier, output trannies, ALL trannies on the board (ALL!), diodes (especially if you find ones placed on the heatsink), resistors that have burnt down (sometimes they burn without smoke - especially the metal film ones)...
Posting the schematics also will help.
Good luck!
Old 2nd April 2005, 01:31 AM   #3
anatech is offline anatech  Canada
anatech's Avatar
Hi Giaime,
I guess when you burn you learn! Sage advice sir.
-Chris
Old 2nd April 2005, 11:46 AM   #4
Giaime's Avatar
Originally posted by anatech
Hi Giaime,
-Chris
Eheh... I've learnt from you Chris!
At least I'm doing some tedious work for you (if helping unexperienced people is tedious... and I don't think so...)
Bye!
Old 2nd April 2005, 06:48 PM   #5
anatech's Avatar
The best way to learn is to teach! It helps you understand the subject better.
-Chris
Old 2nd April 2005, 07:51 PM   #6
Default More info
The tranny I found dead was short circuited and several paths in the board (specially the ones from ground) where burned out. I will start checkig the entire board, please continue to check on me here, your helpis truly appreciated. I will post the schematic in a few days, thanks
Old 3rd April 2005, 12:59 PM   #7
Giaime's Avatar
Ah, burned tracks are a bad sign. They're difficult to repair and they points to a major short that probably fried something also in the power supply. Strange you didn't burn the fuse...
Good Luck! And keep posting...
TDA7294 failure yboorg Subwoofers 15 19th September 2006 08:15 PM
Organ Failure jackinnj Instruments and Amps 4 1st January 2005 03:09 PM
Amp failure .. . DilutedImage Car Audio 11 23rd August 2004 08:40 PM
Page generated in 0.07626 seconds (84.29% PHP - 15.71% MySQL) with 10 queries
