Hiraga "le monstre" - Page 92 - diyAudio
Old 15th April 2013, 12:22 PM   #911
Vostro is offline Vostro  South Africa
Vostro's Avatar
Originally Posted by Telstar View Post
It is very interesting, i saved the schematic.
Most of its japanese transistors are unobtainium nowadays I think but it shows well where they needed to compensate.
Do you know how high were the rails?
Here is the section showing more
The availability of transistors is sad these days, the amp is 2011 model.
Old 22nd May 2013, 03:17 PM   #912
I've gotten my boards designed and etched. Now, the fun part begins!
For power supply, I will be trying a capacitance multiplier, per Rod Elliot's design. I will be using large TO-3 darlingtons for the multiplier because I have some on-hand.
Old 22nd May 2013, 03:22 PM   #913
thoglette's Avatar
Default Monsterous absurdities!
Originally Posted by iaxxaxxai View Post
The original supply is absurd.
How so?
Old 22nd May 2013, 03:45 PM   #914
Originally Posted by thoglette View Post
How so?
Gigantic amount of capacitance for such a low power amp is absurd, in my opinion. I realize that ripple noise must be at an absolute minimum for good sound with this circuit, but when a more practical circuit can achieve the same ends, I see no value in investing $$$ and space in giant capacitors when they aren't needed. And RC pi circuit is such crude energy-wasting filter... would much rather try this capacitance multiplier.
Old 22nd May 2013, 04:00 PM   #915
thoglette's Avatar
Default Ripples in the pond
Gigantic amount of capacitance for such a low power amp is absurd, in my opinion. I realize that ripple noise must be at an absolute minimum for good sound with this circuit,....... would much rather try this capacitance multiplier.
Hmm, I've just re-read the original articles (OK, an English translation, my French ain't what it used to be!). I had remembered much less capacitance on the battery powered version.
One of the recurring memes with class A designs is that their PSRR is usually pretty poor and much effort is spent cleaning up the PS.
I have a JLH in the house and am planning* two new power supplies: a) a battery based one and b) a choke input supply.
I'm particularly interested in whether the current "super" caps and large car (doof-doof) capacitors can help.
A capacitance multiplier sounds interesting if potentially introducing all sorts of signal related noise. Have fun!
(*Don't anyone hold your breath - it'll take a while before I get anywhere close to doing any work. What fool does post grad studies at my age?)
Old 22nd May 2013, 06:24 PM   #916
jeepy is offline jeepy  Switzerland
To my opinion you should ear one Hiraga class A amp one day and I guess you would change your mind. The minimalist topology allows to do what an amp is supposed to do: modulate the voltage at the output in 'real time'.Therefore only ultra high capacitance passive PSU with ultra low ESR can do the job.
A 20W with 0.8A bias class needs 30 Amps! within a few picoseconds when requested. No choice then...
I have got enough original parts to build 5 or 6 amps on the shelf including the NEC 2sd688/2s627 and the TO-3P's for the 30W version. The only issue is the price of good caps! Transformer shoud be a C Core, even a good EI is OK.
The effect of the RC Pi filter on the sound can be discussed. An LC filter is another story. However one of the benefit is the ability to adjust the rail voltages.
Sorry for my approximate English, yes I am French, and also, I met Jean Hiraga a couple of times when I was living in Paris, afficionado of 'La Maison de l'Audiophile' during 15 years. Just my thoughts!
JP
Old 22nd May 2013, 08:54 PM   #917
Hi all
what is the purpose of the 2x 470uf caps on each channel of the le monstre ?
Sheafer
Old 22nd May 2013, 09:44 PM   #918
Provided that supply noise is filtered to a low enough level, I am certain Le Monstre built with a capacitance multiplier will sound good.
Old 22nd May 2013, 09:45 PM   #919
Originally Posted by slr 5000 View Post
Hi all
Sheafer
I'm assuming it is for the purpose of compensating for the inductance in the lead wires connecting the boards to the supply.
Old 22nd May 2013, 09:54 PM   #920
I have built dozens of Le Monstre with capacitance multipliers supplies over the years. It's inevitable, however, to add considerable buffer capacities to their regulated outputs. They have been always much better than passive supplies with or without batteries.
Conversion of Hiraga's "Le Monstre" to a Circlotron tiefbassuebertr Solid State 13 30th May 2015 03:31 AM
Hiraga Monstre with SMPS? weissi Solid State 2 25th July 2008 10:44 PM
Hiraga 30W vs. Le Monstre JohanH Solid State 103 14th April 2008 11:27 PM
HIRAGA Monstre amplifier modules a333bt Swap Meet 5 14th October 2007 04:11 PM
Copyright 1999-2017 diyAudio
