Old 13th February 2013, 05:29 PM   #891
jeepy is offline jeepy  Switzerland
Originally Posted by Williams Audio View Post
hi all,
yes it is expensive thing to be an audiophile, specially with class a pwr amps
but i do have the power supply from an older project so after assembly the monster i will send a report,
best regards,
williams
Yes please. Also I should mention that due the low damping factor of Hiraga's amps it may not work as well as some other topologies with MOSFETS ore more powerfull class AB, with electrostatic speakers. These amps reach the top of the best with big boxes (360 liters) like the 'pseudo' bass reflex Onken equiped with Altec 416, 415 or even 414 in smaller cabinets. Again, my thoughts!
Old 19th February 2013, 07:51 PM   #892
Location: Exchange in Halle (Saale) otherwise a smallish island in the Baltic Sea (Bornholm)
Originally Posted by lineup View Post
- Transistors in my May 2008 final version ( was doing this one day 1 month ago, 2008-05-31 )
input:
2SK170GR + 2SJ74GR .. IDSS is ~ 4-5 mA
... no problem using them without cascode, as 2SJ74 takes 25 Volt.
- But I added cascode at 6Volt level (half supply) with:
BC560C + BC550C
I do not remember, but probably this gives a bit lower distortion.
I usally avoid cascoding JFETs, unless I see there is some benefit from it.
- Second stage, drivers.
BD139 + BD140
Nothing mysterical. They are the best bang for buck drivers ever made and used in audio.
In this amplifier, Le Monstre, they will fit in very well regarding quality.
- Output transistors.
TIP41 + TIP42
I started out testing with MJ15024 + MJ15025 = TO-3 high power.
But these TIP41/TIP42 OnSemi devices performs better.
Probably because they have higher gain.
Rated 65 Watt and as they will only dissipate like 0.8 x12-15 VDC = 10-12 Watt for Class A,
there is no problem using these easy to find & budget price devices.
Lineup
And now I'm wondering what are you using in the 2013 version?
And could you recommend which PSU to build for this amp, is it preferable to use the original?
/Cheers from the other side of Kattegat
Old 28th February 2013, 04:46 PM   #893
Stee is offline Stee  Italy
Stee's Avatar
Default Hiraga TOD
My idea is using Jfet bootstrapped
as Diamond input buffer
like first design
Please download my best audio idea http://www.esafono.it/ISY.zip
Old 1st March 2013, 08:09 AM   #894
Stee's Avatar
Default SANKEN
But these TIP41/TIP42 OnSemi devices performs better...
try 2SA1693 & C. (6A Ic)
Old 11th March 2013, 02:58 PM   #895
triode_al's Avatar
like first design
Fun circuit.
You dont need the transistors above the input that act as a stable voltage source - they will amplify the current on the 1 k and hence destabilise the source itself on the 22k/22k divider.
DAC TDA1541 S1; MC30-Super --> two stage RIAA; SP-6 clone ; 300B PP: 6N7/ECC82, Metalimphy output.
Old 11th March 2013, 04:09 PM   #896
Stee's Avatar
OK but Jfet can't works with 24V
Old 8th April 2013, 07:43 PM   #897
Telstar is offline Telstar  Italy
Hiya,
I decided to build an headphone amp based on the Monstre circuit.
My starting point was the one published by kk-pcb.
Since I wanted much less gain (and lower distortion) I had to touch the feedback resistors. Therefore I chose slow and low-gain driver transistors (the fairchild pair with only 4Mhz Ft) and also added a little compensation on them. I hope this wont make the amp oscillate.
The input jfets are not matched which I have in my scrap bin, likewise for the BC. One heatsink per channel will be used, good up to about 10W.
The two resistors R14 and R15 are just to reduce the power dissipation of the output transistors within the dissipation alu available.
My goal was to keep a nice harmonic spectrum (mostly 2nd and third) and plenty of power/current to drive eventually even orthos, and without using exotic transistors.
I wont start building it before a couple of months, since I have other stuff on schedule, but the simulation looks promising.
PSU will be the regulated sigma22 which I use on most of my headphone amps, with 80-120VA transformer.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 8th April 2013, 09:54 PM   #898
masag1 is offline masag1  Germany
Good luck to your projects.
Which way you want to set the quiescent current?
Didn't you read some articles about this circuit?
Sam
Old 8th April 2013, 11:23 PM   #899
What do you mean by "which way"? If you mean how much, it's about 200mA per output transistor.
Yes, I read the original articles online and all this thread. I cannot use 12x gain to drive phones, therefore I had to do what I did.
If you think there are some mistakes in the schematic, please correct me
Old 9th April 2013, 02:25 PM   #900
"Yes, I read the original articles online and all this thread. I cannot use 12x gain to drive phones, therefore I had to do what I did."
Why you have to use these large, slow output transistors? You only have to drive phones?
My opinion is, there are better solutions for a headphone amp in the DIY.
There is a pix of the last generation "Hiraga 8 Watt" from Klaus Scherm, Germany.
He changed drivers and output trans, and made a tricky setup with current sources for the input Jfets.
sounds great, and was successful at the poweramp shootout at the german "Frickelfest"
Endspiel/es02
Frickelfest 2012/hb/ff12_079
Frickelfest 2012/wl/1 (20 von 60)
Sam
Conversion of Hiraga's "Le Monstre" to a Circlotron tiefbassuebertr Solid State 12 1st May 2011 07:26 AM
Hiraga Monstre with SMPS? weissi Solid State 2 25th July 2008 09:44 PM
Hiraga 30W vs. Le Monstre JohanH Solid State 103 14th April 2008 10:27 PM
HIRAGA Monstre amplifier modules a333bt Swap Meet 5 14th October 2007 03:11 PM
Copyright ©1999-2013 diyAudio
