Hiraga "Le Monstre"
Hiraga "Le Monstre"
Old 7th February 2013, 12:03 PM   #881
Workhorse is offline Workhorse
Workhorse's Avatar
Yes Lineup,
I don't know why this was not proposed by Jean Hiraga himself.
Old 7th February 2013, 01:23 PM   #882
triode_al is offline triode_al  Netherlands
triode_al's Avatar
Originally Posted by Workhorse View Post
Yes Lineup,
maybe it is not a Jean Hiraga then?
SPU --> tube MC/RIAA;
Pass buffer -->300B SE + DN2540 CCS/Buffer; --> 165GMF in TQWT; working on a HYPEXed sub.
Old 7th February 2013, 05:10 PM   #883
Williams Audio is offline Williams Audio  Jamaica
Default ebay kit
HI
what about this kit?
jim's audio
how knows some thing about it?
williams audio
Old 7th February 2013, 05:24 PM   #884
osscar is offline osscar  Latvia
osscar's Avatar
hi!
My LT spice simulation does not show any improvement with this 100r resistor - even upside down - THD slightly worse with this resistor.
My DIY so far: two Leach amps, Pass AB100, Pass F5, B1 buffer, Hiraga le monstre, two LM3875, LM1875, OPA549, 6C33C SE, GU32 PP, 6p3c-e PP, Marsh headphone amp.Phono - OBH-8se, Pacific RIAA, inDiscreet Phono, Whammy headphone amp.
Old 8th February 2013, 04:31 AM   #885
Workhorse's Avatar
Osscar,
My LT spice shows cross conduction above 10khz near clipping without resistor
but with resistor 560ohm, it gives better results.
Old 8th February 2013, 05:17 AM   #886
osscar's Avatar
thanks for the clarification, will try again to sim it.
regards
o.
Old 12th February 2013, 06:05 PM   #887
triode_al's Avatar
Originally Posted by Williams Audio View Post
HI
jim's audio
It is not an 8-watt Le Monstre but a bipolar Le Classe A design of Hiraga, beefed up to 30 watts. It should be nice sounding. It has excellent behaviour to an electrostat for instance - on 0,5 uF still no ringing or overshoot.
Now try that with Le Monstre (it does ring a bit and can't drive low impedance at 20 kHz very good).
The parts list looks ok, give it a try.
The power supply will cost you 5 times the cost of the amplifier boards
Old 12th February 2013, 08:04 PM   #888
thanks for the information about the ''super le monstre''
in fact i have an ACOUSTAT 3 and i am very curios to listen it
i do have a good pwr supply, i am considering to use a regulated voltage that is capable to drive 17 amps
best regards,
williams
williams audio
Old 13th February 2013, 04:54 PM   #889
jeepy is offline jeepy  Switzerland
best regards,
williams
It will work for sure but do not call it 'Hiraga' because it will behave and sound
different due to the parts delivered by JMS (I bought bare PCB's only, they are good BTW) since I have got all the original Xtors. and also because the PSU is crucial for the Hiraga amplifiers. But yes, 0.5F /35V capaciators per rail is expensive! No toroidal Xformer. Even an EI core with screen is much better. A true Hiraga is an expensive project!.... My thoughts.
Old 13th February 2013, 05:15 PM   #890
hi all,
yes it is expensive thing to be an audiophile, specially with class a pwr amps
but i do have the power supply from an older project so after assembly the monster i will send a report,
best regards,
williams
williams audio
Hiraga "Le Monstre"Hide this!Advertise here!
Conversion of Hiraga's "Le Monstre" to a Circlotron tiefbassuebertr Solid State 13 30th May 2015 02:31 AM
Hiraga Monstre with SMPS? weissi Solid State 2 25th July 2008 09:44 PM
Hiraga 30W vs. Le Monstre JohanH Solid State 103 14th April 2008 10:27 PM
HIRAGA Monstre amplifier modules a333bt Swap Meet 5 14th October 2007 03:11 PM
