Old 17th April 2012, 09:45 PM   #841
Originally Posted by ChicagoJTW View Post
If the bias is too low, increase the values of both (!) trim pots to the same value and vice versa whether it's too high.
If your transistors aren't perfectly matched, though, having matched bias resistors on each side won't balance. I try to match Iq rather than R.
No. It is better to balance the output offset by the 100R trim pot.
I wrote that it is preferable to match them close. But it will work sturdy, even if you don't. I don't talk about a heavy mismatch.
Old 25th April 2012, 02:57 PM   #842
Sorry for spamming the thread: Can someone send me the link to a pcb most people are using here??? Want to etch my own PCBs...
Thanks, Dirk
Old 25th April 2012, 03:56 PM   #843
jeepy is offline jeepy  Switzerland
Default Help - 2sa872AE wanted!
Hello All,
Any chance to buy authentic parts somewhere? Thanks a lot.
Old 23rd September 2012, 10:01 PM   #844
Rixsta is offline Rixsta  United Kingdom
Send a message via Skype™ to Rixsta
Hey, i just bought a "le monstre" 12v version, does anyone have any opinions of this ? when i get it ill share more close up pics. and also can anyone recommend the right kind of 12v battery that's not too big (like car batterys are). ill be using this in a car in future but for now want to power it at home so just need a PSU or battery or both so it can be charged. I don't realy have an idea!
Car Amplifier Class A, 2x20W (J .Hiraga schematic) no audison, brax, dls | eBay
Old 24th September 2012, 06:12 AM   #845
neazoi is offline neazoi  Greece
I am powering my le monstre only from batteries. See here Le monstre
Oh and something else, the "le monstre" is 8W, not 20W.
Great DIY site: http://www.neazoi.com
Old 24th September 2012, 11:55 PM   #846
Your site is brilliant! i found it the other day too thankyou, very helpfull!
i thought that there are some variations of the "le monstre" on the internet.
Old 25th September 2012, 12:06 AM   #847
If you see the pictures on the ebay link i posted you'll see the terminals of this amplifier say
GND
REM
+12v
So i presume that is not "dual rail" and this amp must be based on the
"le monstre" but not the same as the original.
Old 25th September 2012, 12:37 AM   #848
Could someone please identify which version of the amp i have ? and any details about it, upgrade ideas ....
thankyou
Old 25th September 2012, 04:45 AM   #849
It is the 20W version of Jean Hiraga's class A amp.
Old 25th September 2012, 05:22 AM   #850
I'm in doubt that your amp really runs class A up to 20W.
At an idle current of 1A and +- 21V supply rails the amp would draw more than 40W per channel (= total 84W). That would be too much power dissipation for the unsufficiant heat sinking capabilities of your amp's casing (I can't see any fans in your pictures).
So I believe it has a class AB setting to lower the power dissipation of the output transistors of the amp and the pulsed supply.
Conversion of Hiraga's "Le Monstre" to a Circlotron tiefbassuebertr Solid State 12 1st May 2011 07:26 AM
Hiraga Monstre with SMPS? weissi Solid State 2 25th July 2008 09:44 PM
Hiraga 30W vs. Le Monstre JohanH Solid State 103 14th April 2008 10:27 PM
HIRAGA Monstre amplifier modules a333bt Swap Meet 5 14th October 2007 03:11 PM
Copyright ©1999-2013 diyAudio
