#821 | |
I've built many of these power supplies, all buffered by high capacities at their regulated exits. None ever showed oscillation. |
#822 |
Dear all,
I got myself a le monste kit from ebay. But I found that the amplifier board has a 9V DC-Offset without speaker connected and 4.9V with a 6Ohm speaker connected. Using these pcbs. I solderd a 1.2K as R1 (input resistor) and 1K on R2 and R3. I also tried: R1=1k and R2=R3=470 and R2=R3=235. The other components are the same as these: ![]() I can't think of another solution. Can you please help me? ![]() As power supply I'm using a: 2x22V 300VA transformer with a rectifier bridge and a 4x(15000uF @ 63V) capacitor bank. Hope you can give me some advise, Duco |
#823 |
How are you using that 2x22v transformer to get the required + and - 12v and
are those TO3 bolts insulated from the heat sink? |
#824 |
#825 | |
Having a DC value means that you have too little 'room' in the potmeter to accomodate for this DC point. No problem:. I suggest a potmeter of 2K5 parallel of the R2R3's. Then you can bias the unit just like is written in the F5 thread in the Pass sections (the Le Monstre works just like the F5; only difference is the other type of output configuration: MosFET versus inverted Darlington). I bought my devices at the shop of Hiraga (lucky) and ititially went for 910 ohms; but I reimplemented it various times. As I lowered the powerline from 14 volts to 13 volts and reduced the current too I found it necessary to reduce the original value from 1 k to below 900 ohms; and all the time inserting new values drove me mad.
DAC TDA1541 S1; MC30-Super --> two stage RIAA; SP-6 clone ; 300B PP: 6N7/ECC82, Metalimphy output.
#826 |
@triode_al
Thanks for your comment ![]() You say, mount in addition a 2k5 potmeter parallel to the R2=1k and one parallel to the R3=1K? This way a have 3 potmeters and I'll be able to adjust the bias the a proper value? Yours, Duco |
#827 |
Is it problem that my Working DC is around +31V and -31V? instead of +22V and -22V?
-Duco |
#828 | |
When you have the correct bias and about the correct DC point you can leave it like that. As I see it: Having 31 V rails on this MONSTRUM SUPERBUS is no problem (as long as the output pairs can handle this voltage and the heat).
#829 |
All right. Thanks! I will get some of these pot meters. If I'm lucky today.
So i can vary the resistance between (1000^-1 + Rpot^-1)^-1 where Rpot can very between just above 0 and 2k5? |
#830 |
-Duco |
| Conversion of Hiraga's "Le Monstre" to a Circlotron | tiefbassuebertr | Solid State | 12 | 1st May 2011 07:26 AM |
| Hiraga Monstre with SMPS? | weissi | Solid State | 2 | 25th July 2008 09:44 PM |
| Hiraga 30W vs. Le Monstre | JohanH | Solid State | 103 | 14th April 2008 10:27 PM |
| HIRAGA Monstre amplifier modules | a333bt | Swap Meet | 5 | 14th October 2007 03:11 PM |
