#811 |
#812 |
Itv is actually in nr 19 of february 1992.
#813 |
Too bad it is one of the very few volumes I missed. Thanks anyway!
Does anyone have tried this? WIMA Double-Layer SuperCap Capacitors and Modules Jp |
#814 |
#815 | |
I think (& I found): N° 19 (nouvelle série) 15 anée N°62 février 92 (55F) lire Français ... I wish a good lecture ... et bonne chance ... I sent a copy-scan to J-P, Allez, salukes, Karel |
#816 |
Ook goedendag Karel,
Ah it's the new series; I was checking the old series which I have completely, but of the new series I just own some, not all. Could you send me a copy-scan of the article as well? The drawing is by Pierre Johannet when I am right. Groet, Pieter |
#817 | |
I do it stande pede .... (dus:direct) ... @ your "p" adres, please (via PM) Nice to read you ... Allez, salukes ... Karel |
#818 |
#819 | |
The powersupply that was mentioned before - had me blow the main fuse of our house I built it with 2 x 25 Amp FETs; just a bit too much. I had not given it a slow start.
#820 |
I remember now why the power supply bounced and oscillated heavily: I had as section after the supply, 56.000 muF capacitors. That is why they were completely opened up to maximum conductivity. The schema has 8 muF and a formal stopper resistor even to reduce the output current. I should try it again that way!
albert
| Conversion of Hiraga's "Le Monstre" to a Circlotron | tiefbassuebertr | Solid State | 12 | 1st May 2011 07:26 AM |
| Hiraga Monstre with SMPS? | weissi | Solid State | 2 | 25th July 2008 09:44 PM |
| Hiraga 30W vs. Le Monstre | JohanH | Solid State | 103 | 14th April 2008 10:27 PM |
| HIRAGA Monstre amplifier modules | a333bt | Swap Meet | 5 | 14th October 2007 03:11 PM |
| Page generated in 0.11954 seconds (79.14% PHP - 20.86% MySQL) with 11 queries |
