Hiraga "Le Monstre"
Hiraga "Le Monstre"
Old 10th December 2010, 06:27 PM   #651
gaborbela is online now gaborbela  Canada
Hello
With 200VA transformer it will be OK.
You will lose 2-3V when loaded may be 4V , don't forget it is a Class A amp! Depend on the bias how high you set it up...
I used 300VA transformer and it was warm my transformer.
The amp bias was over 1A in cold, after1 hour or so 1.2 - 1.3A/ channel..
Greetings
Old 10th December 2010, 06:36 PM   #652
osscar is offline osscar  Latvia
osscar's Avatar
Thanks, I hope so, i will try to load it tomorrow - i still need to get 100R and 220R trim pots for tests - 470R i have but it seems for me to big for GR grade Jfets. I think that the higher voltage as usual -due low voltage drop diodes in rectifier. With standard bridge voltage is lower.
My DIY so far: two Leach amps, Pass AB100, Pass F5, B1 buffer, Hiraga le monstre, two LM3875, LM1875, OPA549, 6C33C SE, GU32 PP, 6p3c-e PP, Marsh headphone amp.Phono - OBH-8se, Pacific RIAA, inDiscreet Phono, Whammy headphone amp.
Old 10th December 2010, 07:05 PM   #653
neazoi is online now neazoi  Greece
Originally Posted by osscar View Post
modu
Look here !
Just checked PSU voltage- 16V without load, seems a bit too high.
I like this company! they accept paypal too. the REAL good ones have 250Euros, this is too much! but the smaller ones are wuite affordable
Great DIY site: http://www.qrp.gr
Old 10th December 2010, 07:16 PM   #654
osscar's Avatar
Yes, in my country it is difficult to find a suitable radiators for class A.
So count aluminum radiator prices + Aluminum and auux.materials (drills, sanding paper etc)- just over 100EUR.
This time I decided to buy
Shipping was very fast, but I forgot to order a perforated chassis ...another option - par-metal.com cases from ebay, but delivery to Europe more expensive.
Old 11th December 2010, 12:07 AM   #655
I feel like it is time to post some updated photos of mine.
Amplifier was setup on 500mW drom and a little bit more when heated
Is it class-A or is it too low that drops into AB??
Here are the photos with my homemade box too. The LED is silicon carbide and yes it is dim
The I/O connections (male ones) are not good yet
Old 11th December 2010, 12:49 AM   #656
bluevas is online now bluevas  Indonesia
Hello guys, i made hiraga with 12 volt and using original components only i using BL grade for jfets with 390 ohm resistor instead 1k ohm. do we have to match every transistor? i never have matched transistor and my le monstre reach over 1 ampere bias and i need to reduce because i have no good heatsinks. what should i do to reduce? should i change the jeft to 2SK246 GR or reduce the 390 ohm resistor? Any suggestions? thank you guys.
Old 11th December 2010, 01:09 AM   #657
As previously suggested you only have to alter the 1K restistor at the base of the driver transistors to adjust the bias. See here for the alignment process I did. Le monstre
Old 18th December 2010, 08:24 PM   #658
osscar's Avatar
Tonight I launched monster in test mode :
ISC outputs, GR grade Jfets - still don't have pot , so i use 2x 100R and 1K for bias - its around 0.4Amps.
square wave 20Khz
clipping
About monster sound- don't know yet, but if there is such osciologram, I suppose that sounds
Old 22nd December 2010, 06:03 PM   #659
HVfanatic is offline HVfanatic  Germany
Hiraga "Le Monstre"
Did I get it right???
I read through it, and extracted the following advise:
1. Get original transistors
2. Use 100 Ohm trimpot
3. For JFets use V type not GR or BL, because V is replacement for Y
4. If Current in output Stage does not fit, change resistors on the collectors of cascode transistors
5. Desired outpot stage current is 800mA (for original design)
Open question: Which board should I take???
The one used at:
Audio Constructions
Which is the size of the PCB (If I have to print, I need the scale factor...)
Regs, Dirk
Old 22nd December 2010, 07:24 PM   #660
osscar's Avatar
You can find in this thread PCB pdf file and print it at 1:1. Do not forget to turn around the FETs. PCB size was 5x6 cm if i not mistaken. I made a little bigger size from one side to have a place 4 screws. You can also use other transistors, only then you will need to experiment with cascode resistors and pot ..Bias approx around 0,5-0.6A if i understood correctly.
Hiraga "Le Monstre"Hide this!Advertise here!
Conversion of Hiraga's "Le Monstre" to a Circlotron tiefbassuebertr Solid State 13 30th May 2015 02:31 AM
Hiraga Monstre with SMPS? weissi Solid State 2 25th July 2008 09:44 PM
Hiraga 30W vs. Le Monstre JohanH Solid State 103 14th April 2008 10:27 PM
HIRAGA Monstre amplifier modules a333bt Swap Meet 5 14th October 2007 03:11 PM
