#511 |
Thank you Dan,
Are you able to make any comparisons with a vacuum tube class-A amplifier? Now that is a little messy cat (they are always like this, so we like them )
Great DIY site: http://www.neazoi.com |
#512 |
Hi Neazoi I cant compare because i have different speakers since then.
-Dan |
#513 |
It seems this topic is inactive for quite a long, I guess all of you are in building stages
I am on building stage too, everything ready, just a few connections left for the PSU capacitors, I will post pictures soon. I have used battery only operation and non-magnetic BNC for the I/O ports in a configuration that I have post here K.Giannopoulos official site
#514 |
#515 | |
#516 |
I just tested the amplifier. all the I/O cables are messy but I couldn't wait to give it a go. It works, it amplifies, this means no error on the circuit, but the 1 Ohm resistors get too hot. Mine are 3.5-4W and the schematic suggests 5W.
With the configuration shown on http://www.audio-constructions.com/m...-schematic.png the voltage drop across the resistors is 2.7V!! I have not made any adjustments yet, I just wanted to see that it works for now. maybe that is why the resistors get too hot? Oh something else I plugged the batteries using cables and no switch and I got a nice spark from the huge initial draw current of the caps.... You wonder if this sparc would exist inside the future added switch? No, if you add a switch there is no spark I have tested it. Not even adjusted and the sound is very transparent and it seems the bass region goes too low. The middle and highs are just excellent I have not heard anything like this before. I wonder how they will be when adjusted. The volume is exceptionally high I guess it is much more sensitive than I thought, perfect for a passive preamplifier, as I had to adjust the volume of the internal attenuator of the CD to the minimum and still it was very loud for my room (I have 90-102dB speakers). An exciting moment to see everything working as expected! I cannot wait to make the adjustments (and replace the 1 ohm resistors with bigger wattage ones?)
Great DIY site: http://www.neazoi.com Last edited by neazoi; 13th April 2010 at 12:07 AM. |
#517 |
I mean the frequency, not the volume of the bass
#518 |
same as mine, too hot but my working voltage is 17v, need to drop to 12 v.
#519 |
hi all fron Burgos (spain)Neaozi tell us more about your final impresiones thanks!pedro
#520 | |
I added a 2K good quality multi-turn potentiometer parallel to each of the 1K resistor to set the bias for class-A and hopefully to reduce the heat on the load resistors. I will let you know very soon of the results. PS. I am running it only from batteries.
| Conversion of Hiraga's "Le Monstre" to a Circlotron | tiefbassuebertr | Solid State | 12 | 1st May 2011 08:26 AM |
| Hiraga Monstre with SMPS? | weissi | Solid State | 2 | 25th July 2008 10:44 PM |
| Hiraga 30W vs. Le Monstre | JohanH | Solid State | 103 | 14th April 2008 11:27 PM |
| HIRAGA Monstre amplifier modules | a333bt | Swap Meet | 5 | 14th October 2007 04:11 PM |
| Page generated in 0.10715 seconds (76.77% PHP - 23.23% MySQL) with 11 queries |
