Old 1st March 2008, 06:47 AM   #41
danieljw's Avatar
Send a message via MSN to danieljw
Default Le monstre Regulated pics
Hi all here is a pic of my regulated le monstre,
and the link.
http://diyaudioprojects.com/Solid/Je...ga-Le-Monstre/
-Dan
File Type: jpg hiraga-monstre-monster-8w-diy-class-a-amp.jpg (46.4 KB, 2764 views)
Old 1st March 2008, 02:15 PM   #42
Tyimo is offline Tyimo  Hungary
Hi Dan!
I have to say the amplifier sounds really really good has any one else tried it ???
Yes, me too, but with unregulated giga PSU like the original. Not bad. It is good for a reference PP amp.
Greets:
Tyimo
Old 1st March 2008, 08:28 PM   #43
danieljw's Avatar
Hi There,
Yes i tested this amp and found very good results both using a reactive speaker load and a resistive load.
Have you built the 20W or 30W hiraga ? I want to build that one next
-Dan
Old 2nd March 2008, 07:55 AM   #44
I built the Le Monster, but I know the Class A (20W version) also very nice sounding amp. Maybe with a bit warmer sound.
Tyimo
Old 26th May 2008, 12:55 AM   #45
bluevas is offline bluevas  Indonesia
what is the good speaker for le monstre ? Any suggestion? Because it's only 8 watt. thank you guys
Old 26th May 2008, 04:24 AM   #46
danieljw's Avatar
Well
Hiraga Mentioned using the onken style enclosures and voice of the theatre enclosures with this amp
but they are a little large and hard to get
i personally have used 86dB speakers with no problems but that is a 5 x 8m room.
-Dan
Old 30th May 2008, 07:23 AM   #47
HKC is offline HKC  Hong Kong
Hi to all
What idss class (GR/BL/V) of the 2SK170/2SJ74 should be used for the Hiraga "le monstre" power amp to get the best sounding result?
Best Regards
Old 30th May 2008, 09:15 AM   #48
lineup is offline lineup  Sweden
lineup's Avatar
hey.
This nobody knows. you just would have to try and listen.
As you ask about 'sound'.
If you mean technically best data of operation into a specific LOAD
it may be easier to try to test or simulate an optimal bias of input stage.
The short answer is, the input FETs should be biased
to get the desired Class A idle current in Output stage.
This current level, would be your choice.
would be different for different wanted power output into different LOADs.
4, 6 or 8 Ohms speakers
This version of Hiraga, in image, uses 2SK246 / 2SJ103
and the bias is set to like 4 mA, for ~ 1 Ampere in output stage.
But I am sure you use some other version / setup
for the Hiraga monster.
lineup
Old 30th May 2008, 09:30 AM   #49
Originally posted by lineup
hey.
Hi Lineup
Thank you for your answer.
Yes I meant technical best data. My speaker load is 8 Ohm and I will use parts as specified on original schematic which the input JFets are 2SK170 & 2SJ74
Best Regards
Old 30th May 2008, 09:33 AM   #50
danieljw's Avatar
Hi All,
Lineup = interesting answer
HKC = see the link in my signature line or google the "class a amplifier site" it has the info in the jean hiraga index.
-Dan
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
chris67
Conversion of Hiraga's "Le Monstre" to a Circlotron tiefbassuebertr Solid State 12 1st May 2011 08:26 AM
Hiraga Monstre with SMPS? weissi Solid State 2 25th July 2008 10:44 PM
Hiraga 30W vs. Le Monstre JohanH Solid State 103 14th April 2008 11:27 PM
HIRAGA Monstre amplifier modules a333bt Swap Meet 5 14th October 2007 04:11 PM
Page generated in 0.12110 seconds (78.45% PHP - 21.55% MySQL) with 12 queries
