Old 19th April 2009, 11:59 PM   #381
njepitt is offline njepitt  United Kingdom
Default Circuit and Photos
I've drawn the final circuit - by hand, I'm afraid, since computer rebuilding is slow... If anything is unclear let me know and I'll try again.
This also seems like a good moment to post a couple of photos, so these follow in the next few posts.
Old 20th April 2009, 12:03 AM   #382
danieljw's Avatar
Send a message via MSN to danieljw
nice work Nigel,
Thankyou for posting your circuit.
I look forward to seeing the pics
-Dan
Old 20th April 2009, 12:13 AM   #383
First two photos are of the PSU. Separate case, intended to be hidden out of the way.. I also designed it so it could handle two monoblocks or even two stereo amps to biamp... although not with separate circuits for the channels.
Old 20th April 2009, 12:14 AM   #384
I should add, this same is used for both the amps shown in the photos below.
Old 20th April 2009, 12:17 AM   #385
Next up are photos of the first Monstre - not the circuit drawn above, but the one using 2N5462/2N54?? jfets and TIP3055/2955 discussed some days ago. The case is much better looking though.....
Old 20th April 2009, 12:18 AM   #386
Same amp, rear view... PLease don't ask why the DC input socket looks wonky.....
Old 20th April 2009, 12:25 AM   #387
And now for the amp we've actually been talking about.... The case is made from a junked car audio power module. (Around here, maybe everywhere, there is a fashion for sound levels in cars that would deafen people on the street at intercontinental ranges. A corollary of this is that the power modules burn out regularly, which is a handy source of heatsink material for free....) The object here was to try and do the amp for as near to free as possible, and to invest more time on the eletronics and less on the case. Of course, Spousal Acceptance Factor is at near-record negative levels....
Old 20th April 2009, 12:29 AM   #388
Detail inside....
Old 20th April 2009, 12:33 AM   #389
And from the front. Any remarks or criticisms of the builds v. welcome.
I should add, at some point I hope to post more detailed remarks on the sound.
Many thanks for all the help.
Nigel
Old 20th April 2009, 01:05 AM   #390
danieljw's Avatar
hey good idea with the plug in plug out connectors for the small signal stuff !!
-Dan
Conversion of Hiraga's "Le Monstre" to a Circlotron tiefbassuebertr Solid State 12 1st May 2011 08:26 AM
Hiraga Monstre with SMPS? weissi Solid State 2 25th July 2008 10:44 PM
Hiraga 30W vs. Le Monstre JohanH Solid State 103 14th April 2008 11:27 PM
HIRAGA Monstre amplifier modules a333bt Swap Meet 5 14th October 2007 04:11 PM
Page generated in 0.10744 seconds (72.43% PHP - 27.57% MySQL) with 11 queries
