Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 2nd September 2002, 07:24 PM   #21
Default error in above power supply schematic
BTW, anybody detected the error in above FET power supply schematic ??
You get 5 electronics engineering experience points (short 5 EEEP ) for that ;-)
regards,
Hartmut from Munich
Old 2nd September 2002, 07:34 PM   #22
rickpt is offline rickpt
rickpt's Avatar
the 2sk30 on the negative power suply is not conected properly...
Old 2nd September 2002, 08:04 PM   #23
Default Great - you got it - wow !!
regards,
Hartmut
Old 3rd September 2002, 08:52 PM   #24
rmgvs is offline rmgvs
I did build Hiraga 20 W and Monstre versions for several occasions. As well do I have one original manufactured 20 Watter for almost 15 years now.
The 20/30 Watter to my ears sounds more friendly and tubelike, almost warm. It has a beautiful midrange and a full bottom end and a silky smooth top end. The Monstre has more detail and depth into the music but can sound thin or harsh on occasions (but in its best moments outperforms the 20 W). I also build the Monstre using heavy batteries and 1,5 Farad of buffer: better still but maintaining forementioned peculiarties. I do not agree that the Monstre sounds like a triode single-ended tube amplifier, only in the transparancy of the sound I can see some similarities.
Interesting to know that I have build some cheap versions of the 20 Watter, using a moderate power supply (around 16 Volts DC plus and minus) and using standard 3055/2955, BD139/140 etcetera. Such an amplifier also has a remarkably good sound to it, bettering almost anything commercially available be a good margin. So for a few hunderd Euro's you can build yourself a pretty power amplifier.
Old 3rd September 2002, 08:56 PM   #25
And I forgot:
I did not build any Pass amplifiers but did have a diy-built version of the later DC single-ended mosfet design (with the big power resistors) that gave around 5 Watts of RMS power.
The sound was not up to my expectations (of course not bad, but way behind the Hiraga) and had a horrible hum in it as well. I do not know about the quality of building and/or used components though and my preamplifier was not up to the task (insensitive and lowish impedance this Pass amplifier). So, not a fair comparison this one.
Rudy
Old 4th September 2002, 02:16 AM   #26
dhengkoel's Avatar
Send a message via ICQ to dhengkoel Send a message via MSN to dhengkoel Send a message via Yahoo to dhengkoel
Dear Stefano,
Do you still interest to use the monstre as a car amp? Try following url for the Power Supply: http://sound.westhost.com/project89.htm
Regards:
ragil.hastomo
:: The last but not least ::
Old 5th November 2003, 05:42 PM   #27
Tyimo is offline Tyimo
Default SE Monster?
Hello!
I have a strange, a bit stupid question!
Is it possible to create a SE version from the original PP Hiraga Class A (or may be from The Monster) as for example the JE Labs made from the Williamson PP tube amp? ( it could be not the best comparison.....)
I would like to hear the diffrence between the 2 operations and because I am an enthusiast of the SE amps.
Thanks!
P.S.: I built the Monster and it is a realy good amp.......
Old 2nd February 2005, 07:49 AM   #28
Default monstre
hello,
after building several class ab an a amplifiers, i have no doubt:
class a is the more natural an sweet sound.
now i want to build "le monstre" but since the transistors of the original schematic doesn't exists anymore, i like to know if some of you have the replacements.
thanks for your answer.
Old 5th February 2005, 07:11 AM   #29
scottw is offline scottw
This may be of interest:
http://web.vip.hr/pcb-design.vip/hiraga.html
scottw
Old 5th February 2005, 08:54 AM   #30
Default my Le Monstre
based on the original design, here my PCB. Any Commenst ?
regards
Dieter
http://www.oesimayers.de/PCB/Monster_8W_tantal_SP.jpg
http://www.oesimayers.de/PCB/Monster_8W_tantal.jpg
Thread Tools
Conversion of Hiraga's "Le Monstre" to a Circlotron tiefbassuebertr Solid State 2 Yesterday 07:48 PM
Hiraga Monstre with SMPS? weissi Solid State 2 25th July 2008 10:44 PM
Hiraga 30W vs. Le Monstre JohanH Solid State 103 14th April 2008 11:27 PM
HIRAGA Monstre amplifier modules a333bt Swap Meet 5 14th October 2007 04:11 PM
Page generated in 0.21822906 seconds (87.51% PHP - 12.49% MySQL) with 11 queries
Copyright ©1999-2009 diyAudio
