Hiraga "Le Monstre"
Hiraga "Le Monstre"
Old 19th March 2009, 11:08 AM   #261
danieljw is offline danieljw  Australia
danieljw's Avatar
Send a message via MSN to danieljw
Originally posted by neazoi
I am glad you wish to make the battery version, that makes two of us
Before I print the PCBs I am trying to add the option to accept a precision trimmer for 1K too, in order to set the bias correctly. Audiomanics, if you could provide the pcb file it would be much easier than trying to edit the image.
http://www.eshops.gr/index.php?act=viewCat&catId=589
I think that is a good idea at first to get the bias 100% right, then (if necessary) replace the trimmer(s) with fixed value. the only thing is the trimmers need to track exactly so both bias resistance values are equal.
-Dan
Old 19th March 2009, 11:09 AM   #262
TzeYang is offline TzeYang  Malaysia
My friend wants me to build a relatively cheap speaker amplifier for his BR2 and I was wondering if the Hiraga Class A is up for the task.
It's 6 ohms and looks a bit demanding so to increase current output any changes such as paralleling output transistors I should consider?
Old 19th March 2009, 11:19 AM   #263
danieljw's Avatar
i would suggest not to modify the Le Monstre too much, it is designed for high efficiency speakers are the BR2 high eff. ??
-Dan
Old 19th March 2009, 12:24 PM   #264
neazoi is offline neazoi  Greece
TzeYang,
Despite of it's simplicity, this can not be considered a cheap amplifier. Finding these odd transistors and FETs, aquiring the big heatsinc and capacitors used, even buying the batteries (if you select this mode), all these are expensive. The resuld with bad quality components may not be as good.
I suggest, If you need something cheap you may try some of these class AB kits available on commerce.
Great DIY site: http://www.qrp.gr
Old 19th March 2009, 12:27 PM   #265
-Dan
You are right, modifying the PCB for that won't be necessary as you need dual gang pontentiometers, because the value must be equal on both 1k bias resistors in each channel. If you need you could just connect two wires and a dual gang pontentiometer at the place of 1Ks...
Old 19th March 2009, 03:21 PM   #266
nelsonvandal is offline nelsonvandal  Sweden
nelsonvandal's Avatar
Why not hava a darlington output stage using SC4793/SA1837 as drivers and sc5200/SA1943 as output transistors? Just fire up LTSpice.
Old 19th March 2009, 09:06 PM   #267
audiomanics is offline audiomanics  Netherlands
audiomanics's Avatar
Yes, i could and i will.. But can you handle Malz++Kassner CAD6 files? As i draw the entire PCB by hand, all soldering-eyes, lines and components are drawn from scratch, so no "self-always-wrong-thinking" PCB program for me..
I tried to find a emailaddress on your site, but for me that's unreadable..
Kees
Old 19th March 2009, 09:30 PM   #268
can you attach them here for the others to see too? if not try www.neazoi.com or www.microwave.gr this is my other sites
Old 19th March 2009, 10:13 PM   #269
danieljw's Avatar
just looked at the datasheets
they look good..... 20/30pF 100/70MHz Ft.....
-Dan
Old 19th March 2009, 10:15 PM   #270
danieljw's Avatar
previously i have started with the initial bias resistance value then soldered alligator clip leads to a dual gang pot to deacrease the resistance value... then turn the amp off remove pot/resistors measure and replace with fixed.... takes a little while but works well
-Dan
Hiraga "Le Monstre"Hide this!Advertise here!
Conversion of Hiraga's "Le Monstre" to a Circlotron tiefbassuebertr Solid State 13 30th May 2015 02:31 AM
Hiraga Monstre with SMPS? weissi Solid State 2 25th July 2008 09:44 PM
Hiraga 30W vs. Le Monstre JohanH Solid State 103 14th April 2008 10:27 PM
HIRAGA Monstre amplifier modules a333bt Swap Meet 5 14th October 2007 03:11 PM
