Hiraga "le monstre" - Page 17 - diyAudio
Old 22nd February 2009, 08:11 AM   #161
Banned
neazoi,
Teflon is an extremely good sounding dielectric material (in sharp contrast to ceramic), but for the speaker wire I would rather chose some type with massive screws. I would certainly use those tantalum resistors.
The 220 Ohm feedback resistors should have a larger mass, say corresponding to 2W power dissipation rating, in example two 390 Ohm 1W in parallel.
Old 22nd February 2009, 10:31 AM   #162
audiomanics's Avatar
Oh? can you explain why?
The outputpower is 8W... this is approx 8Veff to 8 Ohms.
Say i supply 8Veff to 220 Ohm, only ~0,3 Watt is dissipated in this resistor.
Is this a better-sounding- or stability issue?
Kees
Old 22nd February 2009, 11:21 AM   #163
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally posted by neazoi
I have found some tantalum 0.5W resistors from china which cost about 4.50$ each and I was wondering if someone knows if there is a specific brand known for its good sounding properties or if these properties exist in all tantalum resistors.
Shinkoh NOS Japanese resistors are the creme of the tantalum crop. Not all, but some of their properties exist in other lesser realizations. What the others lose is mainly the Shinkoh coherence in tantalum tone. You can feel similar clean tone in metal based Caddock or Vishay even, as well as in other tantalum, but in a more disjointed outcome than with Shinkoh. What kind of tantalum have you found? Any link so to see about them?
Old 23rd February 2009, 07:48 AM   #164
neazoi is offline neazoi  Greece
I have found these tantalums at a reasonable price. any reviews?:
http://cgi.ebay.com/ws/eBayISAPI.dll...m=250367550902
I have also found these to replace the 5W resistors at the power transistors http://cgi.ebay.com/Kiwame-Carbon-Re...742.m153.l1262
So I would like to ask if this is better to go to this type or leave the standard wirewound resistors. The seller claims that they have lower noise than se metal film ones.
Great DIY site: http://www.neazoi.com
Old 23rd February 2009, 08:08 AM   #165
Banned
neazoi,
And even more importantly lower inductance. Much better than wire wound.
Old 23rd February 2009, 09:20 AM   #166
what scares me a bit with the top resistors you mention is that I cannot find the right values (for example I can find 1.5K but not 1K and 1.2K required) and I do not want to series/parallel resistors.
The cheaper brand has many values available.
Old 23rd February 2009, 09:45 AM   #167
For the anode resistors I have found 2.2 ohm instead of 1 ohm. Would it be ok?
Old 23rd February 2009, 09:49 AM   #168
Salas's Avatar
Those you found look like the Audio Note OEM. They lag behind Shinkoh. In that case I would try TAKMAN. Good price carbon with good tech. I had a conversation with some friend that does a lot of evaluation and he told me that they fare better than AN tant for coherency. No direct experience by me yet, so take it with a pinch of salt.
Old 23rd February 2009, 10:02 AM   #169
Oh, I have forgotten the hi-fi collective shop, I have ordered from them again in the past and they seem to have all tha values of thes supreme tantalums
Thanks a lot!
Old 23rd February 2009, 10:09 AM   #170
Banned
neazoi,
the value of the"anode" resistor is pretty critical, should be 1 Ohm.
Conversion of Hiraga's "Le Monstre" to a Circlotron tiefbassuebertr Solid State 13 30th May 2015 02:31 AM
Hiraga Monstre with SMPS? weissi Solid State 2 25th July 2008 09:44 PM
Hiraga 30W vs. Le Monstre JohanH Solid State 103 14th April 2008 10:27 PM
HIRAGA Monstre amplifier modules a333bt Swap Meet 5 14th October 2007 03:11 PM
Copyright 1999-2017 diyAudio
