#101 | ||
Banned
Sigurd,
(As a matter of fact, it was insightfully pointed out by Hiraga himself. That man is obviously right about everything). Quote:
#102 | |
![]() I am not at all afraid of using RED LED for V-Ref. They are excellent when wanting a simple + good solution and not very noisy, in my opionion. ( See Christer, Sweden, investigation link below ) One of the positve things, is when they are put in close contact to the transistor body, when used as a constant current source, RED LED have a fair temperature compensation. Preferably I use flat 5mm RED LED, with the flat surface tightly attached to the flat surface of the TO-92 transistor body. See pratical example how to in my attached picture. diyAudio 2004-06-10, Christer: Some noise measurements for LEDs and zener diodes
lineup |
#103 | |
Lineup - I agree with you. LEDs are superb voltage references in a CCS,
but also when one wants to have a super-low-noise voltage source. If anyone knows of a more low noise voltage source than a blue LED, do let us know. Sigurd Quote:
#104 | |
Lumba - I do not agree that JFETs perform poorly in cascodes.
Correctly implemented, they perform very well. I guess that me and Hiraga do not agree with each other then Not that he says much about JFET vs BJT cascoding in the le Monstre article.... Sigurd Quote:
#105 |
Banned
Sigurd,
they don`t have the ability, are sluggish, cannot handle large voltage swings linearly, their operating area needs to be limited. It`s a hard task even for the best suited video devices. Tubes do that superbly. What about a hybrid amplifier? |
#106 |
for your replies, l asked only because l have some spare devices lying around: i.e; 2n 3055/ m2955's etc as well as some mj 802/ 4502, not to mention some excellent toshiba output devices as used in the aksa pp a/b amp circuit that l could use to build a circuit. but one more question: the second circuit with the bc330/ 560 /TIP 2n3055/ 2955 devices shows no bias adjust pot , is this necessary? or would the circuit work as is? naive of me to ask l know forgive a senile old mans silly questions thank you in advance cheers TC
we all have problems only some people have more than most.... long live the Magyar (Hungarians) in the world! |
#107 | |
Which schematic with the BC330 do you refer to?
There is no bias pot in the le Monstre design. There is a pot to adjust DC offfset to zero, though. Output stage bias is set with the resistors 1k and 1 Ohm. Bias is also dependant on the pot's value - but not its setting. I do not know about the AKSA design, but I can guess that the "excellent toshiba output devices " you mention are the 2SC5200/1943. If so, I would use these instead of the oldish 2N3055/2955. Sigurd Quote:
#108 |
thanks for your quick reply SIGURD, the schematic l am talking about is the one that was posted earlier in the thread on a light blue background: though l do not have the toshiba devices in front of me l think you are probably right as for part numbers go
thanks again cheers TC ![]() PS; do a search on this forum for the aksa, there was a long thread about it a while ago, which if still existing may be enlightening for you
#109 | |
Thank you for the suggestions. They are all good. I will make revise before I send it to factory and post pcb when it is ready. Best Regards |
#110 | |
Lumba,
please post a hybrid amplifier design so I / we can see what you have in mind. Sigurd Quote:
| Conversion of Hiraga's "Le Monstre" to a Circlotron | tiefbassuebertr | Solid State | 12 | 1st May 2011 08:26 AM |
| Hiraga Monstre with SMPS? | weissi | Solid State | 2 | 25th July 2008 10:44 PM |
| Hiraga 30W vs. Le Monstre | JohanH | Solid State | 103 | 14th April 2008 11:27 PM |
| HIRAGA Monstre amplifier modules | a333bt | Swap Meet | 5 | 14th October 2007 04:11 PM |
| Page generated in 0.15607 seconds (82.43% PHP - 17.57% MySQL) with 11 queries |
