How to figure out unknown amp wattage???
Old 31st March 2005, 10:05 PM   #1
Bull is offline Bull  United Kingdom
Question How to figure out unknown amp wattage???
My uncle gave me a power amp he built from a kit ages ago.
It's 3u 19 inch rack mountable,pretty heavy and has 2 very huge capacitors,4x Hitachi mosfet transistors and a large torridal transformer plus other components.
How can I figure out how many watts in rms it gives???
Per channel there are two metal mosfet transistors.
Hitachi J50 [japan 4J2] protected by 3.5 amp fuse and Hitachi K133 [japan 4H1] protected by 9.5 amp fuse.
So could you tell me how much power in rms per channel and @ what ohms it gives it??
Also the torridal transformer sadly has a tiny piece of the insulation [about a few mm hole] on one of the secondary windings[exposing the copper wire itself]. Can I repair this without replacing the transformer instead???
Old 31st March 2005, 11:53 PM   #2
amplifierguru is offline amplifierguru
Account Disabled
From memory Bull, the Hitachi MOSFETS were 100W case dissipation and as such the amplifier would be no more than 50 to 60W at the outside for 8 ohms/channel.
You really need to test the power delivered into an 8 ohm load as the high on resistance and power supply limitations could impact the power output considerably.
Old 1st April 2005, 12:26 AM   #3
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Or use a DC voltmeter and measure the MOSFETs supply voltage
Old 1st April 2005, 01:40 AM   #4
anatech is offline anatech  Canada
anatech's Avatar
Supply voltage may be inaccurate depending on the driver voltages and layout. Best measure into an 8R load.
-Chris
Old 1st April 2005, 01:46 AM   #5
Leolabs's Avatar
Measuring supply voltage just a quick and dirty trick to know output power,without the need of applying input signal.
Old 1st April 2005, 02:09 AM   #6
Account Disabled
That is also a poor indicator because the MOSFET could impose large or small voltage losses depending on the output stage configuration. With 1.7ohm Ron and 8V at current it's significant.
Old 1st April 2005, 10:48 AM   #7
Default reply
So I recon its btw 100w-200w per channel.
But how can I repair the torridal transformer??? its got a nick in one of the turns of the insulation on the secondary winding exposing a few mm of copper wire.
I was thinking heat shrinking but I don't wanna unwind the whole transformer. Or electrical tape maybe.... Its not high voltage but can still cause a short maybe.
Old 1st April 2005, 11:50 AM   #8
Zero Cool is offline Zero Cool  United States
Zero Cool's Avatar
Soundcraftsmen uses the J50/K135 output devices, 2 pairs per channel at they produce 205 watts @ 8 ohms both channels driven etc. 300@ 4 ohms.
Zc
Old 1st April 2005, 12:00 PM   #9
matth is offline matth  United Kingdom
matth's Avatar
If its a kit from the UK with the J50 and SK135 then pennies to a pound of salt its the good old Maplin 150W mosfet modules (see below).
These were optimistically rated at 100W @ 8Ohm and 150W max @ 4Ohms with a max supply of 55-0-55v.
If the transformer windings still have the enamel (spelling?) intact on them then I would not worry to much, just tape it up.
Old 1st April 2005, 12:17 PM   #10
Default reply
Yes the modules per channel look exactly like that.
How to figure out unknown amp wattage???Hide this!Advertise here!
How to figure out unknown specs? FlipC Subwoofers 7 17th November 2008 09:09 PM
How 2 figure out xover freq of unknown xovers? Bull Multi-Way 7 15th January 2008 01:19 AM
Does preamp wattage effect power amps wattage? JonnySwitchblade Solid State 7 4th July 2007 03:18 AM
Speaker wattage[rms] versus amp wattage[rms] Bull Multi-Way 5 9th November 2002 05:55 AM
Copyright ©1999-2017 diyAudio
