How do you make up your mind while choosing a quality power amplifier?
Old 24th August 2002, 07:44 AM   #1
PSS AUDIO is offline PSS AUDIO
Question How do you make up your mind while choosing a quality power amplifier?
What will be, in your opinion, the “best” amplifier to be used for either studio or sound reinforcement?
What are you impressed by?
How important numbers are?
Without listening at it, how will you know if this amplifier will have a great sound (if you think that numbers are not important)?
If numbers are important, what are the most significant numbers (and why are they)?
Thank you for your opinion.
Best regards
Yuri GUTSATZ Jr.
www.pssaudio.com
Old 24th August 2002, 12:34 PM   #2
Elso Kwak is offline Elso Kwak  Philippines
Banned
Send a message via Yahoo to Elso Kwak
Smile Litening Test
Hi Yuri,
I have only one criterion and that is how the amplifier <B>SOUNDS</B> in my system!
Old 24th August 2002, 02:22 PM   #3
mrfeedback is offline mrfeedback  Australia
mrfeedback's Avatar
Default System Listening Test
Originally posted by Elso Kwak
Hi Yuri, I have only one criterion and that is how the amplifier <B>SOUNDS</B> in my system!
Elso, my criterion is how the SYSTEM sounds with 'that' amplifier. - sort of similar thing.
Eric.
Old 25th August 2002, 02:22 AM   #4
NU_NRG is offline NU_NRG
NU_NRG's Avatar
Send a message via ICQ to NU_NRG
PSS AUDIO
taking over this forum?
trying to probe us?
promoting your amps?
feel free to answer!!
Old 25th August 2002, 03:03 AM   #5
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Default Re: How do you make up your mind while choosing a quality power amplifier?
For sound reinforcement, i'd go with something i know sounds good, is close to bulletproof, and is easy to fix if it does break -- Bryston.
for studio work there is more flexibility. Probably a combo of SS & Tubes, choosen to match the speakers (multi-amped) and sound good.
What it sounds like.
Sometimes the numbers will give you an idea. The problem is that often the numbers do not correlate to real world. For instance, without knowing the distribution of harmonics, a single number for harmonic distortion is useless, and often a number that is lower means an amp that doesn'tsound as good.
You can't.
The typical numbers given out are usually not significant. For instance, power is rated RMS into 8 ohms. But what does the amp do into a real speaker -- i have experienced 200 W amps that audibly clip before 20 W amps. But a number like full power into an 8 ohm load in parallel with a 2 uF cap is a good sign that the manufacturer is thinking about stability so that is one that would give you an idea.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 25th August 2002, 05:10 AM   #6
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
How do you make up your mind while choosing a quality power amplifier? Send a message via AIM to Peter Daniel
I look at the top cover. If I can stand on it and it doesn't bend under my weight, I have every reason to believe that the amp is build solidly and it may sound good as well. But it's just me.
To order kits contact me through forum mail.
Old 25th August 2002, 05:32 AM   #7
I also look at the number of output devices and the amount of Black Gate caps. Here is a good example.
Old 25th August 2002, 06:06 AM   #8
frugal-phile(tm)
planet10's Avatar
Has that been built or is it still just a computer graphic? (a pretty good one too).
dave
Old 25th August 2002, 06:09 AM   #9
frugal-phile(tm)
planet10's Avatar
Default Re: Re: How do you make up your mind while choosing a quality power amplifier?
Do you test tube amps the same? Be kinda messy :^)
dave
Old 25th August 2002, 06:14 AM   #10
The amp I posted is Master Reference Amplifier from Krell.
And I never tested tube equipment yet.
How do you make up your mind while choosing a quality power amplifier?Hide this!Advertise here!
have anyone make th HIGH QUALITY AUDIO MIXER darkwind_j Solid State 1 29th July 2009 02:59 PM
have anyone make th HIGH QUALITY AUDIO MIXER darkwind_j Parts 0 28th July 2009 01:58 PM
High quality amplifier power supply for sale supernet Swap Meet 4 19th December 2008 10:22 AM
Choosing a amplifier - What's in a name? Flyin11 Car Audio 11 28th October 2007 07:35 AM
Choosing amplifier for PC speakers soundNERD Chip Amps 9 27th September 2003 01:10 AM
