I just fixed a friend's Sony receiver. Nothing special. Put in new Sankens on one channel. Sounds good, and has been running on the test bench speakers for about 5 hours.
Thing is, when I push the B speaker switch to on (nothing connected) sound stops on the A speakers. Seems strange. Just wanted to check the schematic to see if it is supposed to do this for some reason if there is nothing hooked up to B. The B switch is a different type than the A switch for some reason. Just seems strange and wanted to be sure all is well before giving it back. Nothing bad seems to be happening when B is on (outputs don;t heat up or anything) and music comes back as soon as it is switched back off. Hmmm...
Twisted Pear Audio |
#2 |
This is a low end receiver, and as such, the two speaker sets are wired in series (not parallel) when you activate both. So when you push the B button without any speakers connected to A, the circuit is open and voila, no sound. I've attached a clipping from the schematic of another low end Sony receiver (STR-DE405). You can see how the speakers are connected by examing it.
#3 |
Thans I thought it might be something like that, then I thought, naw, it couldn't be THAT cheap.
#4 |
Yup, it is. Just fixed a Pioneer that does the same thing.
-Chris |
#5 |
At least it's not mine
#6 |
Oh yeah! Ditto.
| Sony Str-D311 question | Kirk64 | Solid State | 2 | 30th April 2012 05:53 PM |
| SONY DAS-702 schematic needed... | ALP | Digital Source | 7 | 22nd December 2007 06:37 PM |
| SONY CDP-XB930 schematic needed! | Rene Snebang | Digital Source | 3 | 15th April 2007 07:24 PM |
| Sony Home Stereo System STR-D311 | lonejakyl | Parts | 1 | 23rd February 2006 08:24 PM |
| Page generated in 0.08007 seconds (71.37% PHP - 28.63% MySQL) with 11 queries |
