Rega Brio (one channel dead)
Old 7th August 2005, 03:55 PM   #11
cosinus is offline cosinus  France
Hi there
Thank you for your replies. I finally decided to buy all the components for the dead channel, and to replace everything. It cost me something like 10. The fixed channel didn't sound as good as the original one, but it was OK and I gave the amp to a friend for his countryside house. Maybe the transistors were of poorer quality.
Here are the schematics that I received from rega. These guys are very friendly and provide a good support. I believe there is no problem posting the diagrams of such an old amp, as it may help passionate people.
FrancoB -> you may have the second version of the amplifier, where they changed the components' numbers (what a good idea). The diagram is almost the same. They just added a couple of fuses.
A question for the experts here: how to adjust IQ ? Where to measure the 15mA ?
Another question: I just bought another brio, almost identical, on a secondhand market. I would like to improve it. Is there anything that can be done, without changing too much the amp? Use better opamps ? Is there a pair of better transistors that could replace the 2955/3055 ? Anything else?
Best regards
Old 7th August 2005, 03:57 PM   #12
P2
Old 7th August 2005, 04:00 PM   #13
P3
Old 7th August 2005, 04:04 PM   #14
P4
Old 7th August 2005, 04:05 PM   #15
P5
Old 7th August 2005, 04:07 PM   #16
P6...
Old 7th August 2005, 04:09 PM   #17
...and P7
Old 7th August 2005, 07:02 PM   #18
jaycee is offline jaycee  United Kingdom
The transistors probably need to be matched for best quality.
Measure the voltage drop over R13 and R16.
I really wouldn't bother. If you changed the outputs you would probably have to change the driver transistors, and that would mean going to TO-126 or TO-220 packages that wouldn't fit in the PCB.
Old 7th August 2005, 10:54 PM   #19
consort_ee_um is offline consort_ee_um  United Kingdom
This amplifier design has an interesting history. It was originally designed by Texas Instruments (i think in Bedford England) as the "Texan" kit for "Practical Wireless" magazine back in the 1970's.
Rega borrowed the design but used more rugged output transistors than the original TIP41/42.
The main feature is that the output stage has some voltage gain which allows the op-amp to run off low voltage supplies.
I believe the original Texan design did not have quiescent current setting adjustment which can give the dreaded crossover distortion.
Old 14th August 2005, 05:41 PM   #20
I googled for Texan amplifier and about the only relevant ref I could find was:
http://www.angelfire.com/sd/paulkemble/sound5.html
which is part of
http://www.angelfire.com/sd/paulkemble/soundindex.html
excellent site which I had not come across before
scroll down to the fifth circuit down on the first page
Like the owner of the brio I am intrigued as to how such an amp would sound with better specified components.
Sgs/thomson have an old little known power buffer, the L149 which could be used as an integrated output stage for an op-amp for those wishing to play with a simple circuit. I am surprised this device is still avaliable from digikey
Rega Brio (one channel dead)Hide this!Advertise here!
Help. dead channel on GFA 555. chucker Solid State 4 17th May 2008 08:45 AM
Dead channel Carlp Tubes / Valves 15 1st February 2007 04:54 AM
2020 T-Amp Kit: One Dead Channel mourip Class D 5 14th February 2006 02:09 AM
HELP with a rega brio! jercab Solid State 1 5th October 2005 02:43 AM
Peavey 8.5C DeAd cHaNnEl Pbassred Instruments and Amps 3 10th May 2005 12:44 AM
Copyright ©1999-2017 diyAudio
