Old 29th March 2005, 03:32 PM   #1
Smile QSC Amp Problem
The problem is with a QSC RMX 2450 amp basically the amp is operating normally and without problem, then it will suddenly blow the fuse in the AC plug regardless of whether there is anything going thru the amp. There seems to be no pattern to it as it will go for several weeks without problem then it will pop several fuses one after another for no apparent reason... I’ve isolated it and ran it on an AC circuit that I believe nothing else is drawing current from. Plus we also have another amp of the same type in the building that is unaffected... (Eliminating buliding AC problems)... Strange one huh!! Anyway do you guys know of any test I can do to determine the nature of the problem as I don’t want to send it to the repair shop unless it’s actually broken...
Thanks for your help
Darren
Old 30th March 2005, 10:18 AM   #2
Jontie is offline Jontie  United Kingdom
Default QSC Amp Problem
The only time I've had this sort of problem, it was due to a tantalum bead capacitor going intermittently short-circuit in a power supply. I don't know whether this particular amp has any, but it might be a good place to look.
Old 31st March 2005, 05:56 AM   #3
Enzo is offline Enzo  United States
Why not contact QSC and bounce the problem off them? They may have some insights.
mtx amp problem [[help!!]] fuzzypinkhat45 Car Audio 3 8th July 2008 05:34 AM
CDM 2/29 Problem – HELP! Bassivus Digital Source 29 23rd December 2007 10:00 AM
FRD/ZMA Problem Twisted85 Multi-Way 5 4th December 2006 01:19 PM
p3a problem MaXiZ Solid State 17 16th July 2005 07:14 AM
Page generated in 0.07040 seconds (71.28% PHP - 28.72% MySQL) with 10 queries
