Hi, I have a question regarding this simple common design:
http://www.tallstrom.com/amp.gif To keep a long story short, I have some already fixed power supplies: + 24V and +-40V The OP can´t handle +-40 so I figured I could use the 24V for it, and "lift" the input signal to 12V. However, how does this work with the +-40V for the output transistors? I guess I have to use a number of DC coupling capacitors..? And some gain thrown in in the feedback loop. Do I lift the inverting input of the OP to 12V also? Would this work at all? Thankful for any help. Cheers Martin |
#2 |
All you are doing in this circuit with the 2 transistors is amplifying the current, i.e. lowering the output impeadence of the op-amp. You can't get voltage gain from an emitter follower circuit and therefore limited by the maximum voltage the op-amp will handle and will not get enough voltage swing for +/- 40V. Also you have to bias the two transistors so that they are just barely on and not operating in cut-off, not with the bases connected. Because the Vbe turn-on voltage takes a small amount of time to achieve, you can't amplify full 360 degrees signal and you are left with crossover distortion unless the transistor is already biased on above the cut-off level.
| Push pull BPA | warriorcookie | Chip Amps | 6 | 4th October 2008 05:41 PM |
| 12V push pull PSU. Need help. | darw82 | Power Supplies | 4 | 3rd June 2007 02:42 AM |
| modify parallel push-pull EL84 to single push-pull | chungtat | Tubes / Valves | 12 | 3rd November 2005 11:25 PM |
| Is the Zen really a push-pull? | Kashmire | Pass Labs | 3 | 17th August 2004 09:07 PM |
| Double push-pull versus single push-pull | jraraujo | Tubes / Valves | 19 | 19th October 2002 12:23 AM |
