Hafler P500, need schematic, manual, and some help
Old 19th November 2007, 02:54 PM   #21
anatech is offline anatech  Canada
anatech's Avatar
Hi Tom,
Sometimes fan noise can be reduced with a good cleaning. Behind the fan blades too. You really have to remove it for this. Failing that, a new fan is required. These should not be very noisy in normal use as they are not turning at full speed, that's why I think there may be an issue there.
Yes, it's too bad that there's at least 45 min driving from Ajax to Georgetown.
I used to drive that often enough. I'd call it 1 1/2 hours if traffic is really good. The moon if your running around after 4:30 PM on a weekday.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 22nd November 2007, 01:09 AM   #22
Cheaplow is offline Cheaplow  Canada
Hi Chris,
Thank you so much for the information. I will try to clean the fan again in X'mas time.
Tom
Old 28th December 2007, 02:50 AM   #23
audioguru7 is offline audioguru7  United States
Question to those with the P-500 - Which potentiometer do you adjust the bias at and which fuse do you use to measure?
On my P-500 I see 4 potentiometers and 2 pairs of fuses. A picture would be great.
Mike
Old 28th December 2007, 06:04 AM   #24
djk is offline djk
R.I.P
djk's Avatar
http://www.hafler.com/techsupport/pd...00_amp_man.pdf
Bias pot P2 is right in the middle of the board. Adjust to 350mA.
There is one dual fuseholder per channel. Pull one fuse (either one) and measure the current (to avoid killing yourself turn amp off and wait a minute before sticking your fingers in it). Repeat for other channel.
Candidates for the Darwin Award should not read this author.
Old 28th December 2007, 12:11 PM   #25
Thanks djk. I do have the DH-500 manual but the layout of the P-500 is different, so I wasn't sure how similar it was.
Will give it a try and report back. Also, I'll try cleaning the heat sink as I am still trying to eliminate the high-speed fan mode after only a few minutes of listening.
Mike
Old 29th December 2007, 07:17 AM   #26
djk is offline djk
R.I.P
djk's Avatar
"Also, I'll try cleaning the heat sink as I am still trying to eliminate the high-speed fan mode after only a few minutes of listening."
They get hot when you run them hard, or at 4R.
I replaced the quiet 35CFM stock fan with a 110CFM howler to keep the amp running at 4R (with the stock fan it will shut down).
No matter how quiet of a fan you use, you will still be able to hear it at low volume levels.
This is one of the quieter fans on the market:
http://www.comairrotron.com/cgi-bin/...ameter_unit=in
You might want to try something like this and re-wire the fan switches for medium and high speed only with a single resistor for an appropriate speed. I find it less annoying if it isn't switching speeds all the time.
Old 15th March 2017, 06:14 PM   #27
soulman25 is offline soulman25  United States
I too have acquired a Hafler P 500 to work on for our sound company. It has virtually no output But all of the voltages from the power supply our correct. Could it be that the final output transistors are just old and need to be replaced . Along with the 20K Uf caps used in the power supply. If anyone has any ideas on this amp please let me know.
Old 15th March 2017, 06:35 PM   #28
Talking Hafler P500 Power Amp
Hi I have a Hafler power amp on my bench model P-500 . If anyone has a Service manual or a schematic on this animal ,that would be great. It has a very low output signal but all of the voltages from power supply are there. Could it be that the final output transistors are old and need to be replaced along with the 20K UF caps in the power supply. I checked the voltages to the _+- output section and they are symetrical. +- 90 volts. Please help if you can. As I really need that schematic. Thanks one and all.
Old 15th March 2017, 08:08 PM   #29
Update on the Hafler P500 I'm working on , There is plenty of output signal coming from the collectors of the output transistors, QP & QN 113s , as I can see it on my scope , but if I go to the output terminals there is little if any signal at all. In between the output transistors and the output terminals there is , I think its a relay. That may be my problem as its not clicking to let the signal pass on to output terminals. Any help is greatly appreciated . Thanks.
Old 20th March 2017, 04:53 PM   #30
I pulled the relay out and soaked it in alcahole for a day . Reinstalled it unit still wont pass signal.
Hafler P500, need schematic, manual, and some helpHide this!Advertise here!
Hafler P500 bkfix Solid State 0 30th March 2009 01:19 AM
Need checklist advice for health check-up - Hafler P500 (DH-500) Power Amp toby_somerset Solid State 7 15th August 2007 09:28 PM
hafler p500 rogerb Solid State 1 12th May 2007 03:30 AM
Cambridge P500 Schematic needed... Hurtig Solid State 1 5th October 2005 02:48 AM
