Hafler P500, need schematic, manual, and some help
Old 14th April 2005, 11:47 PM   #11
djk is offline djk
djk's Avatar
"zero tempco point for the Hitachi lateral MOSFETs is ~100mA per device. "
Bias spec on the DH500 is 350mA, 100mA per device (pair) plus 50mA to run the front end.
Line idle current will be on the order of 2A; this is bias, fan, and transformer loss.
Old 22nd August 2006, 03:59 PM   #12
audioguru7 is offline audioguru7  United States
Still4given,
Sorry to bring this post back up from the dead, but I'm not able to e-mail you since I'm a new user.
Do you still have the Hafler P500 manual that Hafler sent you? My amp works good but the fan kicks into a high-speed mode after only a few minutes of listening. I think there may be something internally wrong causing it to heat up faster.
Please let me know
Thanks,
Mike
Old 22nd August 2006, 04:10 PM   #13
anatech is online now anatech  Canada
anatech's Avatar
Hi Mike,
The fan speed is controlled by thermal switches. They short out resistors as the heatsink gets hotter (looks like two stages, three speeds). Either a switch is faulty (unlikely) or the heatsink is running that hot.
-Chris
Old 22nd August 2006, 05:24 PM   #14
Chris,
Thanks for the information. I would have to agree with you that the switch is not likely at fault since I can feel the warm air blowing out the back of the unit. I'm going to attempt a "bias adjustment" and report back on if that helps or not.
Thanks!
Mike
Old 22nd August 2006, 05:58 PM   #15
anatech's Avatar
Good luck Mike.
-Chris
Old 22nd August 2006, 06:02 PM   #16
BobEllis is offline BobEllis  United States
BobEllis's Avatar
A few years back I was told by the factory that bias should be 450 mA total per side (ammeter in place of rail fuse). At that level mine would kick up to the mid speed all the time. I reduced bias to 200 mA total and it stays on low unless I go crazy. It hasn't runaway despite 10 years of nearly continous use since.
Dust in the tunnel will have a tremendous effect on the efficiency of the sinks and therefore fan speed. Clean them out if you haven't done so already. At least a blast of compressed air helps but is not as good as brushes/pipe cleaners.
Old 2nd April 2007, 03:19 AM   #17
jdqb7@yahoo.com is offline jdqb7@yahoo.com  United States
Default Hafler P 505
I just obtained one to replace a DH 500, any suggestions on how to obtain manual/schematic, for upgrades, and changing the inputs to unbalanced RCA 's ? Thanks.
Old 17th November 2007, 06:41 AM   #18
Cheaplow is offline Cheaplow  Canada
Hi Terry,
Can I have a copy of the service manual including the schematic ?
My P500 has been sitting at the corner in basement for years. I recently hooked it up to my speakers. It powers up but nothing can be heard from the speaker. Thanks.
Old 17th November 2007, 05:15 PM   #19
anatech's Avatar
Hi Bob,
It sure will!
I generally blow them out first, then wash them in a degreaser to get rid of any deposits. Obviously this is an overhaul at that point. Not a yearly thing. Compressed air once a year will keep it pretty clean.
Hi Cheaplow,
Too bad you aren't any closer to me.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 19th November 2007, 01:41 AM   #20
Chris,
Yes, it's too bad that there's at least 45 min driving from Ajax to Georgetown. In fact, there is nothing wrong with my p500. The problem is with myself because I forgot that my p500 is a 220v version. As I connected it to 220v ac, the light is up. Anyway, I would appreciate if somebody can let me have a copy of the schematic for future reference. My p500 sounds very good but I hate the noise from the cooling fan.
Tom
Hafler P500, need schematic, manual, and some helpHide this!Advertise here!
Hafler P500 bkfix Solid State 0 30th March 2009 01:19 AM
Need checklist advice for health check-up - Hafler P500 (DH-500) Power Amp toby_somerset Solid State 7 15th August 2007 09:28 PM
hafler p500 rogerb Solid State 1 12th May 2007 03:30 AM
Cambridge P500 Schematic needed... Hurtig Solid State 1 5th October 2005 02:48 AM
Copyright ©1999-2017 diyAudio
