Can project 03 drive a sub (4ohm driver)
Old 27th March 2005, 07:34 AM   #1
goldyrathore is offline goldyrathore  India
Cool Can project 03 drive a sub (4ohm driver)
I am in need of a sub amp which can give 100Watts RMS of clean power for sub use. How good is project 03 at Rod Elliot's site? It is obvious that I will have to use it with output transistors in parallel for a 4ohm driver. How much of clean power can it give (at what supply voltage ?) and what is the damping factor which is critical to have a tight control of the driver?
Also if I put more transistors in parallel. Can it drive 2 Ohm loads.
I am particularly interested in this amp since it uses readily available parts.
Thanks in advance,
Goldy
Audio enthusiast/hobbyist
Old 27th March 2005, 08:39 AM   #2
kinser is offline kinser  Israel
kinser's Avatar
Send a message via ICQ to kinser Send a message via MSN to kinser
goldyrathore,
I think you should use project 03a which is an updated circuit of project 03, also if you look at the shcematic on project o3 you will se that it sais:
"Figure 1 - 60W Power Amplifier Original Circuit Diagram (
Don't Use This Circuit! )"
Hope I helped you!
Kinser
Old 27th March 2005, 04:20 PM   #3
Smile My clarification
As I said earlier I am interested in this amp in particular because the components are vailable locally here in Bangalore, India. The amp in Figure 1 is not to be used but Figure 1a can be used. I am concerned about the fact that "The amp is capable of driving 4 Ohms, but it is starting to push the limits of the transistors".
Any suggestions. Will parallel operation of 2955 and 3055 solve the 4ohm load problem?
Thanks,
Goldy
Old 27th March 2005, 04:43 PM   #4
kinser's Avatar
goldyrathore,
I saw figure 1a and i think that u could just add an extra pair of output transistor and you are ready to go! but i would go with project 3a if I where u!
Kinser
Old 27th March 2005, 05:06 PM   #5
edl is offline edl  Hungary
edl's Avatar
hello Goldyrathore!
your idea will works!
you know, here is the article:
http://sound.westhost.com/project03.htm
here there is a figure, that one:
http://sound.westhost.com/p03_fig2.gif
I made a two channel stereo "P03" amp for with 4ohm speakers.
I used an 56V-CT (2*28V) toroidal transformer, rated 200VA.
This way I had 100W-RMS on 4ohm.
The 2955/3055 pair don't likes +/-40V rails, so I used two pairs of BD911/BD912 per channel. This transistors are so cheap, but they are excellent!
If the 911/912 are not available in Bangalore, you can use any other complementary power devices, with Uce min 80V!
If you have got any question or problems, let's answer!
Good luck, my friend, Hello from Hungary!
Old 30th March 2005, 02:33 PM   #6
Smile Can I bridge this amp to get more power?
Has anybody tried bridging this amp to get more power? Since I want to use it for a sub, I think it is better to have some headroom.
Thanks in advance,
Goldy
Can project 03 drive a sub (4ohm driver)Hide this!Advertise here!
How can LM1875 drive loads lesser than 4ohm? goldyrathore Chip Amps 11 15th April 2009 02:49 PM
Can a 8ohm driver be mated with 4ohm tweeter? Nordic Multi-Way 10 2nd October 2007 11:53 AM
4ohm Sub driver to 8ohm Sub amp? WBFAir Multi-Way 10 31st March 2007 01:29 AM
substituting 4ohm for 8ohm midbass driver sreten Multi-Way 1 19th December 2005 01:27 AM
Copyright ©1999-2017 diyAudio
