NAD 3130 amp popping speakers - Page 5 - diyAudio
Old 12th June 2005, 12:27 PM   #41
anatech is offline anatech  Canada
anatech's Avatar
Hi KBK,
The input coupling cap on an NAD is critical, although I'd include it on any amp. There is a 0.5~0.6V DC offset between the base and emitter of a bipolar transistor that is temperature sensitive. This is cancelled in a differential pair, but not with the classic NAD input. They achieve DC offset control by injecting a current that hopefully tracks temperature. The result is that the DC offset "wants" to drift with temperature. If you replace the input transistor, it may or may not be outside the gain range to be compensated. Same for other transistors in this circuit.
It's an iffy circuit that relies on component tolerance to a "bogey" value to work. I can't tell you how many techs get hopelessly stuck on these. Even when using real exact replacements.
-Chris
Old 13th June 2005, 10:41 PM   #42
djk is offline djk
djk's Avatar
I believe the 2400 has a regular diff input pair.
Old 13th June 2005, 10:57 PM   #43
anatech's Avatar
Hi djk,
I don't have a schematic so I can't tell. I see reality is seeping into NAD's design team.
-Chris
Old 19th September 2006, 07:51 PM   #44
algoape is offline algoape  France
Hi hash_dac,
Sorry this thread is quite old now, and you may have moved to other horizons away from this amp...
I recently got a nad 3130, for a very low price too.
And face quite the same distorsion problem as you on the left channel; it ihappens not all the time,
It is lasting only a few minutes then disappears. Seems occur when the amp is cold but not always.
It goes away if i disconnect-reconnect the left input ...
Did you finally find out the cause and get it resolved on your amp?
Thanks for your rep.
Old 19th September 2006, 08:06 PM   #45
ash_dac is offline ash_dac  United Kingdom
Originally posted by algoape
Hi hash_dac,
Dry solder joint on a transistor.
....but I smoked the NAD! oops. It had dry solder joints everywhere, bulging cap's, noisy pot's, and corroded RCA jacks.
Freeze spray was really useful in finding the problem part in my case.
Speakers popping and static noise at all volume levels PPI Amp duderino201 Car Audio 21 8th May 2010 09:19 PM
NAD 3130, more to love? espressogeek Solid State 9 10th June 2009 11:17 PM
NAD 3130 Integrated Amp dtm1962 Swap Meet 1 22nd March 2009 12:25 AM
Schematic of a NAD 3130 AlexRox Solid State 5 10th August 2008 06:36 AM
Need some advice on popping speakers Joshw Car Audio 8 3rd June 2005 07:44 AM
Copyright 1999-2017 diyAudio
