First of all I am new to this forum and already it has helped me with this issue. Got the downloadable service manual for this amp from a post search. Thanks for the info.
I moved the amp the other day and noticed a brown hard goo under on the bottom cover. I researched the net for possible problems and found out about the 10,000 uf caps that are a known problem. I opened the amp and that is the area where the problem seems to be. The amp is working ok, but I don't like when my stuff is not right. Lookin around for the caps has taught me these caps are not real easy or cheap to come by. Has anyone done this repair? Where did you get your caps? Costs? What should I know in advance before changing them out? (ESD and normal percautions I am aware of) Onkyo USA has the caps for about $300.00 for the 8. Different part number so I suspect they upgraded the part for this issue. Seems like a straight forward job, but I like to ask others that have done something for advise to make a job smooth if possible. Thanks in advance for any info. J.T. Stanton |
#2 |
JT,
Any cap of similar dimensions will work. As you know to look for the ESR/ Cap/ voltage rating. Chances are for the same size, newer caps will be higher capacitance or voltage rated, this is fine as long as it does not exceed 20% of the capacitance because then you may be taxing other components. I would not pay $300 for 8 standard 10,000uF caps.... |
#3 |
As I recall, the PSU caps in the M 508 are known to have a hard time, and even blow up frequently due to the low working voltage of the original caps.....
![]() As k-amps write: find some with a working voltage 20% over the supply As I can see in the service manual, the M 508 has a rail of 74.5 Volt DC and 80V caps
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#4 |
to make the answer less complicated: You can likely replace the capacitors with some 10,000uF 100V capacitors from any reputable manufacturer and be just fine. Shop distributors for price.
Jesus loves you. |
#5 |
Not as bad as some amps I fixed in the past (affectionally called Flame Linears by some of my fellow techs) in which the manufacturer assumed that cap voltage ratings were conservative and used higher rail voltages than cap V rating!! (if memory serves 75V caps and 80V PS)
#6 |
B Cullingford:
Is that the same "Linear" company that assumed that an output stage with max capacity of 250W easily could deliver an output of 200W for years after years
#7 |
that would be them - oh how I loved replacing PCB traces with wire!
#8 |
And is that the same guy who rates his new toys as capable of driving 2400 watts into 1 ohm with BJT's that have less total dissipation than what they are driving at 1 ohm?
#9 |
It sounds very possible
#10 |
Just to be sure, the hard goo is not between the capacitors and the board is it?
Or is it actually leaking out of them? because some manufactureres use glue for the large caps on the board. |
| Onkyo TX-930 | mplehning | Solid State | 11 | 17th May 2008 11:07 PM |
| Onkyo Power Output Stage, capacitor between bases of EF pair? | capslock | Solid State | 5 | 13th April 2007 03:40 PM |
| Onkyo TX-18 | hardcore_bmxer1 | Solid State | 1 | 16th October 2006 02:18 AM |
| Onkyo 20C | sorenj07 | Multi-Way | 7 | 8th October 2006 07:46 PM |
| Onkyo M 508 | beks | Solid State | 18 | 31st May 2004 07:25 AM |
| Page generated in 0.12217 seconds (72.81% PHP - 27.19% MySQL) with 10 queries |
