transistor glue?
transistor glue?
Old 25th March 2005, 12:14 PM   #11
SkinnyBoy is offline SkinnyBoy  Australia
Banned
Send a message via MSN to SkinnyBoy
Originally posted by DigitalJunkie
"Artic Silver" (IIRC) is the name of the silver kind my friend uses on the CPU's in his PC's..
It's supposed to be "the best" heatsink-goop(technical term ) around.
yeah, its called that because its made by Arctic Cooling :P
Old 25th March 2005, 02:44 PM   #12
anatech is offline anatech  Canada
anatech's Avatar
transistor glue?
Yup. A bit of Canada in a jar. Amps can't overheat up here!
-Just kidding of course.
Burned fingers made the most important point. The mounting surfaces must be clean and flat. That's more important than the brand of goo you decide on. Oh yeah, it gets everywhere, and keeps coming back.
-Chris
Old 25th March 2005, 03:31 PM   #13
bigpanda is offline bigpanda  Hong Kong
Just somebody brings up the question :
Is there any glue, I mean real glue, for sticking smaill piece of heatsinks to some unexpected overheated components. Of couse they have to be good heat conductors but preferably non conductors for electriciity.
Old 25th March 2005, 04:29 PM   #14
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
Yes, there are: in fact many old PC CPU were attached to their heatsink with some kind of thermal glue. I have here in front of me a CPU with that glue; also I see on my RS catalogue that there is a glue called Heatsink Glue (850-984 in my old '97 catalogue)...
I always remember that Marantz 1060 (Chris knows what) which had some transistor heatsinked with Bostik glue. Go figure...
Old 25th March 2005, 04:35 PM   #15
anatech's Avatar
transistor glue?
Thermally conductive epoxy. I use it sometimes (mine is blue). Made by different manufacturers in various strengths. Two part like regular epoxy. It works very well.
-Chris
Old 27th March 2005, 02:31 AM   #16
mpmarino is offline mpmarino  United States
mpmarino's Avatar
There is also thermal 2-way tape. It seems OK for non critical apps where it wouldn't be the end of the world if it were seperated. Again, you need surgically clean surfaces.
Crazy Yankee.
Old 27th March 2005, 04:13 PM   #17
anatech's Avatar
transistor glue?
Hi mpmarino,
I haven't seen the tape. Cool.
I have grabbed the soldering iron by the wrong end when I'm tired & rushed. Hurts for a long time. Stinks too.
-Chris
Old 27th March 2005, 05:31 PM   #18
cunningham is offline cunningham  United States
I sat my hand down on top of a hot soldering iron about 8 years ago. Won't forget that.... I still have a scar that runs half the lenth of the side of my hand. Lesson is don't be in such a hurry...it can set you back.
The bit about washing the heat sink compound from your hands when your done is good advise. The silicone base zinc oxide compound burns like heck if you accidentally rub your eyes.
Old 27th March 2005, 05:37 PM   #19
anatech's Avatar
transistor glue?
Hi cunningham,
A thread should be started entitled "stupid things we've done". That way new tech's won't feel so bad.
-Chris
transistor glue?Hide this!Advertise here!
Can bias transistor mount on top(body) of output transistor?? Leolabs Solid State 26 28th April 2016 10:34 PM
What glue to use feverdog873 Multi-Way 17 5th January 2009 11:46 PM
Gel glue loninappleton Full Range 18 29th December 2007 01:03 AM
What glue to use? wixy Multi-Way 26 6th February 2007 11:49 AM
Glue like (better than ) RTV........ ashok Everything Else 8 5th June 2004 12:40 PM
