Symmetrical Clipping - diyAudio
Old 16th January 2001, 12:06 AM   #1
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
Ok...
What is an accurate way to test for symmetrical clipping in an amp? How is it executed? What equipment is needed?
If it's not too complicated, can step-by-step be provided?
Thanks!
Old 16th January 2001, 01:03 AM   #2
FYC is offline FYC  Hong Kong
The only equipment that you can rely on is a CRO, without this you will not be able to do it accurately.
Old 16th January 2001, 01:57 AM   #3
vdi_nenna's Avatar
Unhappy Symmetrical Clipping
What's a CRO? Cathcode-Ray Osilliscope? Never heard of a CRO.
If I get a CRO, what do I do with it? Set it to monitor the output for the onset of distortion in the + and - halves of a waveform?
thanks
Old 16th January 2001, 07:18 AM   #4
promitheus's Avatar
Yeah thatīs what a CRO is. You monitor the output and with a test tone from either a generator or a test cd you try to bias the amp so when clipping it clips even (the same ) on top and bottom of the wave form. It not a cheap set up But itīs the only that does the job. It would be easier if you could use someone elses. Like from a Lab or a friend .
Old 16th January 2001, 07:20 AM   #5
Yes, CRO is oscilloscope.
If you got one, then you should hook up a signal generator to the input of your amp. (or if you have a test CD with tone signals). Hook up your CRO to the output of the amp. Slowly turn up the signal, you should start to see the waveform on the CRO grow larger and larger but keeping a good sine waveform.. At some point, you should start to see the top of the sine waveform flatten out, the amp is clipping. At such stage, turn your bias adjustment VR until you see that the flatten portion of your sine wave is symmetrical on the top and bottom. You are done.
Old 16th January 2001, 05:26 PM   #6
vdi_nenna's Avatar
Got it. Thanks.
Old 16th January 2001, 05:47 PM   #7
Freddie is offline Freddie  Sweden
I've made a test cd, a year ago or so..
So If you have a CD-burner you can easily do one yourself.
I used Cool-Edit I think, It could generate perfect sinewaves. I downloaded a shareware version on the net.
Old 18th January 2001, 03:49 PM   #8
Not to be pedantic, but...
How I would do this more accurately is stretch the time/div out as far as you can and still see the top of the wave. Then measure the clip's length. Then switch your trigger from + to - and measure the bottom.
That should eliminate some of the guessing.
pixie
Old 19th January 2001, 12:49 AM   #9
My experience is that stretching too much on time scale will flatten the sine waveform so that it is not so easy to tell where it start to clip. Keeping 2 full cycle on the CRO screen to me give the best picture.
This tuning is not intended to be mV type of work, so extreme accuracy is not the prime concern.
Old 19th January 2001, 07:17 AM   #10
promitheus's Avatar
Default use triangle wave
If you have a triangle wave on your tone generator it would be more helpfull. At 1 KHz and with a triangle wave you can see clipping right away. When you see both parts of the wave start to clip at the same time then your adjustment is correct.
symmetrical supply PLH amp umut1001 Pass Labs 5 2nd April 2008 03:03 AM
Symmetrical differential vs symmetrical non-differential VAS suzyj Solid State 30 21st August 2007 03:44 AM
70V 5A symmetrical PSU HELP :D firefart_1st Power Supplies 4 20th July 2007 07:59 AM
From symmetrical to N-channel only bigpanda Solid State 9 20th March 2006 02:24 AM
Symmetrical crossover Bricolo Multi-Way 14 1st June 2003 09:32 PM
Copyright Đ1999-2017 diyAudio
