binary said:Originally posted by darkfenriz
This amp definitely needs driver stage
MikeB
Your calculations about temperature assume no heatsinK????
I thought IRF540/9540 is better choice than IFRP240/9240 because of lower on resistance...
I' d prefer the IRF540 / 9540 because they are easily found in Brazil and are cheap (about US$1.5 each one).
Of cause, the output transistors will be assembled in a large aluminum heat sink. [/B]
binary
are you there
- did you build it?
- what was the final schematic used, compared to first post?
- how did this amplifier behave?
- any problems?
My Attachment shows first post schema, before eventual modifications
35 Watt amplifier using IRF Hexfet would be a good level to use,
for the average audio builder, including me
Regards everybody
lineup
