My Crescendo amp pics - diyAudio
Old 21st August 2002, 08:57 AM   #1
Eccu is offline Eccu  Finland
Eccu's Avatar
Default My Crescendo amp pics
Couple of questions still open...
Number of the fuses:
a: Do I have put only one to the primary side?
b: Or also two fuses to secondary side? And where should these two fuses to be placed. Before rectifier or after rectifier or after capacitors?
Earthing:
a: Do I have connect the earth ( from wall socket ) merely to amplifier metal case? So speaker terminals and RCAs are isolated from case. And power supply zero point ( center point of PSU filter capasitors ) is separate from this earth.
b: Or do I have connect earth ( from wall socket ) to power supply zero point ( center point of capasitors ) and from there to metal case? And still keep speaker terminals and RCAs isolated from case. Or how I must do it?
right way boy... u sold farm and bougth booze
Old 21st August 2002, 09:03 AM   #2
Eccu's Avatar
An another pic.
U see that I keep my filter capasitors in (empty) Ballantines whisky box...
Old 21st August 2002, 09:34 AM   #3
wuffwaff's Avatar
Hi Eccu,
looks nice!
You only need a fuse on the primary side. The original Crescendo had two extra fuses in the plus and minus feeds placed on the circuit boards.
Connect all of your grounds to one central point and from here with a resistor or NTC to the chassis. Connect chassis to wall socket (earth)
In some cases you must disconnect the input ground from the central point to avoid humm (it will still be connected through the 10ohms resistor)
william
P.S. Donīt you think you caps will smell when they get warm?
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 21st August 2002, 11:28 AM   #4
Eccu's Avatar
BIG Thanks again Wuffwaff.
Do you mean this? (See attachment)
But should I connect speaker - (minus) to PSU capasitor center point or should I connect it to amplifier board (speaker -) like in schematic?
And now very stupid question: Is NTC same think as Thermistor?
Old 21st August 2002, 02:05 PM   #5
wuffwaff's Avatar
eccu,
yes, ntc and thermistor are the same. I would connect speaker - at the caps and not at the board (star earthing remember) just like in your drawing. The only connection thatīs missing in your drawing is inlet ground.
william
Old 22nd August 2002, 06:04 AM   #6
Eccu's Avatar
I think you mean that "OUTLET" in picture... that where purple wire is connected to ground point on the chasis.
I have still one question about NTC... so what is its meaning and function in this case?
And what kind of its got to be?
Dam my English is bad... I try make my best.
Old 22nd August 2002, 05:42 PM   #7
wuffwaff's Avatar
Eccu,
the NTC stands for "negative temperature coefficient" and means that the resistance of this part goes down to a few ohms when it gets hotter. So as long as your central earth point and chassis ground have almost the same potential thereīs no current flowing (NTC has a high resistance now) and no chance for ground loops and humm
As soon as the central earth point gets positive or negative, current will start flowing through the ntc and it will get lower resistance and even more current will be flowing
Now (or even before) your "differential switch" (donīt know the englisch name) will detect that thereīs more current going into your amp then is coming out and shut the whole house down
If you donīt have anything like a diff switch the high current to ground will activate the fuse in your amp and prevent other devices to get a lethal potential via the interconnect ground.
When I think about this itīs really time that I connect my central earth point to ground one of these days
william
Old 23rd August 2002, 06:03 AM   #8
Eccu's Avatar
Big thanks...
crescendo amp neeraj Solid State 10 22nd April 2012 12:13 PM
Help for the Crescendo ME!! FeFe Solid State 11 14th June 2005 02:56 PM
Problems with Crescendo ME RickIvo Solid State 9 6th November 2003 11:19 AM
Pictures of Crescendo Amp? Eccu Solid State 0 26th July 2002 08:17 AM
Copyright Đ1999-2017 diyAudio
