Old 19th March 2005, 12:23 PM   #1
Question Help - my Linn Majik IP Phono inputs are not working?
I recently bought a 2nd hand Linn Majik IP Integrated Amp and Linn Basik turntable to have a nice little Analog system, but I am having a problem - my MM Phono input is not working. Everything else on the Majik (inputs, outputs, amp section) works fine, and the turntable works great on my other system. Any ideas on what may be wrong?
Any help would be appreciated!
Thanks,
John
Old 18th April 2005, 03:36 PM   #2
Achiel is offline Achiel  Netherlands
Send a message via ICQ to Achiel
Are you sure you bought one with a phone input unit. They are sold with and without it. If it's without the phone board it can be used as an normal input. At my wakonda it's called "ph/aux2" and I dont have a build in phono board.
I think you'd better open it and give it a look inside.
Grtz Achiel.
Old 20th April 2005, 01:26 PM   #3
Thanks for the reply! I have opened it and can't tell much from the inside. I can see the sneaky connections on the circuit board and the jumpers to change the default volume and display settings, but nothing hinting at the Phono/Aux.
On the back of the component, above the input it has 3 boxes, Phono MC, Phono MM, and Aux 2. The Phono MM box is checked. Also, the model number on the bottom is Majik IP (where I believe the P means Phono). I think the "line" models are designated Majik IL?
I any case I tested the input with a regular line input (from my Mimik CD), and from the turntable. Even at full volume, I get no sound. I think the input is dead, but I don't know any more diagnostics to perform or how to fix. Any ideas?
Thanks,
John
Old 21st April 2005, 01:26 AM   #4
It seems like it's broken indeed. I don't have technical knowledge about the majik phone stage.
Maybe someone other has or can help with some sort of scheme. Good luck.
Greetings Achiel.
Linn Majik vs. Gainclone salesmonster Chip Amps 5 19th August 2007 07:18 AM
Phono Box Suddenly Not Working chrislacon Analogue Source 1 21st June 2007 01:11 AM
dc offset at phono inputs mmerig Analogue Source 20 28th December 2006 04:41 AM
Linn Wakonda Phono klinker Analogue Source 0 28th March 2006 02:58 PM
Speaker level inputs on ads P440 not working Pete H Car Audio 8 14th May 2005 11:20 PM
Page generated in 0.07112 seconds (72.35% PHP - 27.65% MySQL) with 10 queries
