Old 20th March 2005, 08:07 PM   #21
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
Yes Chris, I thought so, but the original head has a loose contact inside it on the left channel, that's making noises and sometimes just cuts out. It had to go... Maybe I will find a replacement...
Old 20th March 2005, 08:47 PM   #22
anatech is offline anatech  Canada
anatech's Avatar
Hi Giaime,
Interesting fault. Most heads were defective due to wear. Do you know what kind of head it was? (Glass=Ferrite, permalloy, standard "butter" or Sendust - really good head). Maybe a picture of the original head looking at the face and rear.
-Chris
Old 21st March 2005, 11:45 AM   #23
Giaime's Avatar
Nooooooooo! I just asked to my friend what was the thing about that head, and he said that wasn't the original, it's a cheap thing extracted out of a Panasonic portable mono recorder... DoH! The original one just didn't existed: he had this tape from another person already missing it... Bad situation I guess.
How strange: I convinced myself that was the original head because, apart from the lack of treble, it was a clear, spacey-sounding head! Much better than the head I just put in (btw it is even worse: bad hiss, some 50Hz buzz, zero treble and guess what... absolutely mono!)
What do you mean about Glass=Ferrite? It is a metallic head, not a glass one (do they exist? Maybe I just don't know...)
Should I look for a Technics replacement or a specific brand?
Old 21st March 2005, 11:49 AM   #24
Carondimonio's Avatar
IIRC, the 615 had Permalloy heads...
Old 21st March 2005, 12:17 PM   #25
Giaime's Avatar
So, I've got to ask for "Permalloy" head? Sorry Carondimonio can you tell me the italian word for it if you know? It would be useful...
Old 21st March 2005, 12:25 PM   #26
Permalloy sounds the same in every language, I guess... it' s a standard name for a magnetic alloy.
Now, I do not think you can just ask for any Permalloy head out there, put it into your deck and get good results. The electrical characteristics of the head may vary quite a lot.
Try to get on ebayand old Technics deck from the same age (be sure it' s a 2-head deck, though) and get the head from it, chances are the heads are pretty interchangeable. Or try to get the original spare part from Technics/Panasonic, although I doubt it' s still possible to find it.
Ciao,
Bruno
Old 21st March 2005, 12:31 PM   #27
Ciao Giaime,
look here:
Technics 615
And no, I' m NOT the seller...
Ciao,
Bruno
Old 21st March 2005, 01:52 PM   #28
Giaime's Avatar
Thank you Bruno, but I'm not looking for an original replacement. I got this deck for free and I have fery few cassettes, I just want an average sounding head. One that sounds. I will look in hi-fi and electronic shops...
Old 21st March 2005, 08:53 PM   #29
anatech's Avatar
Hi Giaime,
This is scary, I know how to spell your name without looking!
You want a permalloy head because it's in the same family. A different type of head will have specs way out from the original. Older parts jobbers that used to sell cassette heads may have some. Technics did not charge very much for their heads to begin with. So an original may be worthwhile for you. I remember about $20.00 CDN.
If it doesn't work right, you won't use the deck. If it does, you may like it.
Thanks for the info Bruno, I had no idea what type of head it was.
-Chris
Old 22nd March 2005, 12:29 PM   #30
Giaime's Avatar
Thank you Chris! Yes, that's scary: many friends that I've known for years can't spell my name... That's a strange one even in Italy (btw it is my real name).
Thanks for the info!
My DIY UcD amp from the junk box acid_k2 Class D 34 5th April 2012 08:03 AM
I found more junk! Magnetmaz Tubes / Valves 9 28th December 2007 08:49 AM
New Chip Junk classd4sure Class D 85 20th September 2006 08:24 PM
Tip for Junk box Zen PSU? SM7UYJ Pass Labs 2 4th April 2005 09:57 PM
got some interesting junk yosh Parts 2 27th June 2004 09:01 AM
Page generated in 0.13063 seconds (62.48% PHP - 37.52% MySQL) with 11 queries
