seeking comment on first pcb design
Old 16th March 2005, 03:05 AM   #1
ultrachrome is offline ultrachrome  United States
Default seeking comment on first pcb design
This is two capacitance multiplier power supplies on the same board with a star ground point in between. This is between the rectifier and amp boards for ESP P36.
So I used .150" traces where I could. Sorry I don't have the part names but the caps are 4700uF, 1000uF, and 470uF all 63V. The transistors are TIP2955 and BD139.
The transformer will initially be a 400VA 25+25 later replaced by two 30+30 transformers if I like the amp.
Old 16th March 2005, 04:42 AM   #2
Greg Erskine is offline Greg Erskine  Australia
Greg Erskine's Avatar
hi ultrachrome,
I thought DoZ requires a 0-40v DC supply, 30-0-30 will be too big.
Greg Erskine
Old 16th March 2005, 04:48 AM   #3
I have traced one capacitance multiplier for each channel. A 30+30 transformer yields 38VDC according to Rod's construction article. I'm going to use a 25+25 tranformer because it's what I have on hand so I estimate I will end up in the lower 30s.
Old 16th March 2005, 04:52 AM   #4
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
What pcb / schematic software are you useing ?
Is this a regulator circuit ?
Old 16th March 2005, 04:57 AM   #5
The first image I posted is a screen scrape of expresspcb. I drew the schematic I just posted in ms powerpoint.
Old 16th March 2005, 06:10 AM   #6
Banned
For any reason..
Id change the layout so that input is at one end and out put is at the other. Not them both at each end...
Do yoU need help i could help you..
J
Old 16th March 2005, 06:28 AM   #7
I drew one side and saw that I could fit another supply on the board by rotating it 180 degrees. This seemed like a good solution because this board would fit with its long side near the back panel of the enclosure, with the transformer.
This allowed each channel the shortest power wiring possible.
I'll post a pic of the enclosure tomorrow.
I rarely turn down help.
Thanks.
Old 16th March 2005, 06:30 AM   #8
Banned
Like this. : O )
Could you tell me the voltage in and out that yuo are trying to achieve ? I also have a better regulated schematic you could use instead of this one.
Jason
Old 16th March 2005, 06:33 AM   #9
Banned
Or this one.
Old 16th March 2005, 08:10 AM   #10
Sorry, I stand corrected, I should have read it more carefully. Rod knows his stuff.
Greg Erskine
seeking comment on first pcb designHide this!Advertise here!
Comment on my DIY Sub Design htgeek Subwoofers 22 8th April 2005 05:26 AM
Please comment this design promise Solid State 0 20th January 2005 05:25 AM
comment on my cabinet design..... AudioGeek Multi-Way 1 3rd May 2004 06:18 PM
Seeking comments on (new?) design dooper Multi-Way 13 9th February 2004 01:17 PM
comment on this design, please. JAZZ2250 Tubes / Valves 6 24th November 2002 10:45 PM
Copyright ©1999-2017 diyAudio
