Old 15th March 2005, 05:39 PM   #1
urant is offline urant  Mexico
Default Quad Clone
Hi.
I’m a new poster in this forum, even tough I have know about it for some time.
I’ve been meaning to build a small 50w amp for some while now, and the time is ripe to do it.
Now, I really like the idea of a Class A solid state amp…what I don’t like is all the wasted power. I live a city whose average summer temp is around 40C, so the idea of an amp/heater is not very pleasing.
The “current dump” concept that the old Quad amps used really looks nice…and I’m a bit more that curious to build one and see how they work.
Does anyone have a suggestion on which would be a good one to clone?
Thanks for you time
Old 15th March 2005, 05:40 PM   #2
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
Maybe the 405
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 15th March 2005, 06:58 PM   #3
analog_sa's Avatar
Maybe the 405
A fine amp, difficult to blow and well suited for tropical climate. But sounding as if it were class A it ain't.
Old 15th March 2005, 07:02 PM   #4
405man is offline 405man  Scotland
I would suggest you build a clone of the Quad 306 which with a proper split powersupply is capable of excellent results. This is very similar to the current and highly regarded 909 but with less power
Stuart
Old 15th March 2005, 07:11 PM   #5
Zombie is offline Zombie  Sweden
Oh dear, analog_sa praising a Quad amp...what has happened?
Hope it doesn't snow on midsummer
Anyway, if you'll make a 405, take a look at another recent thread here, a guy from Romania? had some variations to his cloned 405-2...cleaner supply for the input opamp and class A amp...
Old 15th March 2005, 07:12 PM   #6
Hi ACD, thanks for your reply
Why do you recommend the 405?
Why not the 306 for example?
By the way, I have access to some really nice PCB software, and if anyone’s interested, I’ll post the finished artwork here
Old 15th March 2005, 07:36 PM   #7
analog_sa's Avatar
He,he,he. I built a few of these at the time - it was the only amp not blowing when my home made electrostats started sparking. Of course i built them with 'high-end' opamps (5534 was real good in 1984) and 3 separate PS, down to the transformers. Apart from an annoying power-on thump (different time constants) i thought it was a reasonable amp. Then again it was more than 20 years ago
Old 15th March 2005, 07:53 PM   #8
Not that I am an expert, but what's the use of cleaning up the supply to the opamp when the class A amp gets a lot of the crap anyway? Your solution with separate supplies helped a lot I can imagine?
But it seems the 909 looks pretty much like the 306, so much hasn't really happened with that amp in 20 years...or has it?
Cheers
T
Old 15th March 2005, 08:29 PM   #9
analog_sa's Avatar
It actually did. My main objection against the 405 at the time was the rather flat presentation - good image width but not much depth and especially height. Not too much cues of the recording venue, etc. First experiment was to separate the opamp supply; pleasant enough but not groundbreaking. The class A amp separation was indeed a monumental improvement. I might have also used parallel output transistors but can't say for sure. The case was Krell-sized as the main transformer was way oversized (650VA?).
I never experimented with later Quads. As the opamp is mostly taken out of the main signal path they might well sound better.
Old 15th March 2005, 09:05 PM   #10
Hi
The schematic I was planning to use is from
http://www.flashbacksales.co.uk/acat...zip/306cir.jpg
Analog_sa, is this the one you would build?
Do you mean a separate power supply for the OPAM and board and to optically link it to the clase A section via a fotodiode and fototransistor?
I was planning to use Mentor Graphics to draw the board since it can do PCB signal and thermal analysis<=
This is a bit off topic, but I’m beginning to design a digital amp: FPGA implemented DPS processor control, PWM modulated power supply, digital input (no ADC) thermally compensated output switching MOSFETS, a fuzzy logic based feedback-feedfoward error correction.
I’m pretty useless in analog, but in digital, that’s another story.
Kit building Quad 405 Clone JonLawes Solid State 133 10th February 2011 07:34 PM
Wtd: Quad 606 Clone fusion Swap Meet 0 28th December 2006 08:23 PM
Quad 405-2 clone al2002 Solid State 19 15th May 2006 06:14 PM
QUAD CLONE,OUTPUT 30v,NEED HELP. SHARMAN Solid State 10 26th June 2005 02:44 AM
Page generated in 0.12263 seconds (73.11% PHP - 26.89% MySQL) with 10 queries
