#21 |
-you cannot know the resistance of this water/salt mixture
-you can have some problems if youre testing for a longer period, because Cl is coming out and Na transforms to NaOH which is dangerous too, if youre a smoker you can blow your room out because of H coming from reaction too.. (if you wanna know the reaction formula: 2H2O + 2NaCl + Energy (from ur amp) --> H2 + 2NaOH +Cl2) |
#22 |
Banned
i was going to say the same thing i think ill stick tomy oil one and my resister one.. ..
J' |
#23 |
diyAudio Moderator Emeritus
Is it possible to make dummy load with car halogen lamp?
1 lamp at 12V can dissipate 150W, means the R is about 1ohm. Can I make 4ohm load with 4 of this 150W halogen lamp in series? |
#24 |
Hi.
I made this box from scrap. The following resistances are available: 2 * 7.33 Ohm /150W 2* 7.6 Ohm /100W 1* 7 Ohm /250W Cooling is done with a fan. I don't think it could remove the worst-case-heat, but for shorter periods its fine. Regards TroelsM
Need more time... |
#25 |
This is my own made double dummy load. In a simple package there are two dummies made from nickel-chromium edge wound wire each of 8Ù / 20°C or 8,16Ù / 100°C. And each of power about 2,5KW.
| Power load, dummy load (pic) | luka | Power Supplies | 43 | 9th February 2012 02:50 PM |
| 8 ohm dummy load | andrewe1 | Parts | 43 | 9th May 2011 05:44 AM |
| Tri Dummy Load | raudio1969 | Parts | 0 | 25th February 2009 01:14 AM |
| dummy load | reddish75 | Solid State | 72 | 3rd April 2008 01:15 AM |
| Resistors for dummy load? | wintermute | Solid State | 54 | 3rd February 2004 11:59 AM |
| Page generated in 0.14328 seconds (47.43% PHP - 52.57% MySQL) with 11 queries |
