Old 13th March 2005, 03:34 AM   #1
rodolfo is offline rodolfo  Mexico
Question irfz44
anybody know how to build an amp with irfz44
low power
tks tks
Old 13th March 2005, 05:33 AM   #2
IRFZ44 is lower voltage high current n-ch. I don't know of any accual p-ch complement. The Rds on is very low and ment to drive very low impeadence switch. It is a hexfet design...not very linear. Of course no transistor is truely linear, this one is not even close. If you biased two in class ab as a push pull transformer coupled or quasi complementary circuit, it might work. As for quality, . There are better choices of mosfets to use for audio. These are typically used in low voltage hi current smps circuits, like car amp power supplies.
Old 13th March 2005, 05:54 AM   #3
tks
Old 16th April 2005, 08:43 PM   #4
DG_6MT is offline DG_6MT  United States
Default audio amp using irfz44
i know that the xtant 1001dx uses the irf244 transistors (as one blew out on mine not too long ago) This xtant is a pretty high end, mono channel, class D amplifier. Its fairly large and the board is definetely complex. The amp uses about 13 of these, with some irfz44n's and a few others (not very electically inclined....just learned how to even read a transistor). The amp puts out 1000 watts at 1 ohm and is pretty damn bad*ss....just too bad it broke. Well, i thought id share this info with you as i came across this looking for another irfz44 to replace the one that blew out with. Anyone know a good supplier?
if you don't live for something, you'll die for nothing
Old 16th April 2005, 09:58 PM   #5
ilimzn is offline ilimzn  Croatia
IRFZ44 and IRF244 are very different transistors. In fact, you are unlikely to find an IRF244 as they are long out of production...
Old 17th April 2005, 04:14 AM   #6
ok
I have but of 100 of those thanks
Old 17th April 2005, 08:13 AM   #7
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
Originally posted by rodolfo
ok
Build a Class A amp with 20 of them in parallel for each channel
Old 18th April 2005, 01:45 AM   #8
quasi is offline quasi  Australia
quasi's Avatar
Default Quasi-comp class A
I agree, you could build a multi-channel medium power quasi-complimentary class A power amp of excellent quality.
Let me know if you want a cct.
Cheers
Old 18th April 2005, 04:26 AM   #9
Stocker is offline Stocker  United States
Why not just post up a circuit anyhow? Likely as not, it will spark someone's interest.
Jesus loves you.
Old 18th April 2005, 08:31 AM   #10
you can try pass's zen amplifier.i had done that now past three months i am using that .it is giving excellent sound.
Replace IRF540 in IRFZ44 Dj BASS AMP Solid State 10 29th August 2011 04:11 PM
IRFZ44's in orion 250 SS64 Car Audio 10 1st May 2009 01:12 AM
how much power can i get fro IRFZ44? Astro Power Solid State 26 4th February 2005 02:12 PM
Aleph With IRFZ44 Jay Pass Labs 7 24th February 2003 10:59 AM
Using IRFZ44 in place of a IRFP044 Nicwix Pass Labs 6 19th July 2002 12:31 AM
Page generated in 0.11061 seconds (78.39% PHP - 21.61% MySQL) with 10 queries
