Voltage regulators for line level circuits
Old 5th September 2002, 07:20 AM   #61
HarryHaller is offline HarryHaller  United States
Banned
Default LEDS
~5mA should work fine for the 10 volt reglator. I also think you could use 4 greens and 1 red LED and get about 10 volts with 1K to 2 K across the adjustment terminals. The LEDs provide better reglation and lower noise than resistors for a given adjustment current. test under close to load current and heatsink the regulators. You can also pre regulate the 5 volt regulator at 10 volts with a another regultor for better PSRR and less power dissapation.
Old 5th September 2002, 03:52 PM   #62
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Voltage regulators for line level circuits Send a message via AIM to Peter Daniel
Default 4 greens and 1 red LED and get about 10 volts with 1K to 2 K
Harry,
Your comments are as usually right on the point. Thanks.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 5th September 2002, 04:58 PM   #63
Banned
Talking Lucky guess.....
You will get better regulation with the 1K to 2K resistor than 100 ohm.
H.H.
Old 12th September 2002, 06:35 PM   #64
Flemming J P is offline Flemming J P
Send a message via MSN to Flemming J P
I planing to build some regulators with tracking preregulators using lm317/337.
As far as I can understand from this thread, using diodes instead of a resistor from adjust to ground improves regulation, is this also worth the effort when using a tracking preregulator? And should go with diodes on the preregulator as well?
HarryHaller also mentions 1K to 2K resistor rather than 100 ohm (it's the resistor between output and adjust right?) does this also apply for lm317/337?
Old 24th April 2003, 06:45 PM   #65
dipchip is offline dipchip  United States
dipchip's Avatar
Default LED based regulator
Harry,
Would this LED regulator method work well with +15V
or does the number of LEDS introduce more noise?
Thanks,
Craig Beiferman
Voltage regulators for line level circuitsHide this!Advertise here!
Line level subwoofer out voltage? thefish Subwoofers 2 3rd February 2007 08:29 PM
line voltage level metebalci Tubes / Valves 2 1st March 2004 01:45 PM
Line Level, Balanced Voltage Level... dkemppai Solid State 3 11th December 2002 12:04 AM
Sulzer Regulators vs LT1085 in digital circuits Dr.H Digital Source 0 29th July 2002 06:56 AM
Regulators for digital circuits Peter Daniel Digital Source 49 5th July 2002 11:58 AM
